Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-15-2006, 10:17 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Blue smoke after boost
After I boost the car I get a good bit of blue smoke coming out the exhaust. I know that blue smoke means burning oil. As long as I am on the throttle there is no smoke but when I let off and the car is slowing down, especially when still in gear, smoke will puff out the exhaust. The turbo I put on there was used but seemed to be in excellant shape. Still has very little shaft play. I haven't had to time to do a compression check but I was just hoping this is a sign of the turbo going bad.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-15-2006, 10:22 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: Blue smoke after boost
I'm having a bad day and can't really think through things... but I might suggest checking the PCV valve... I know if that's bad it can build up pressure and cause piston ring blow-by... and I'm thinking that if the pressure can vent enough under boost, it might still have a problem venting when the TB is closed...
(forgive me if this sounds irrational, I'm having sugar problems this morn and can't think clearly)
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 12-15-2006, 10:24 AM
Holset powered 420a
The PCV valve is pretty new, I can still check it out to make sure.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-15-2006, 10:29 AM
Mikelb's Avatar
hmm... 420a @7psi... I'm trying to think... it might be awhile (waiting on everything to clear up...I didn't eat breakfast this morn and I'm suffering now)...
I remember your car, but I can't member when you got it turboed... how long has it been turboed? and when did this start?
And a/b where do your EGT readings sit?
What kind of shaft play has the turbo got? side-to-side? or in and out? some side-to-side is ok, but there should be no in and out...
I would think if it were the turbo, it would be dumping oil when under boost...
Have you checked your intercooler? if the turbo is really bad, there should be oil in there...
Old 12-15-2006, 11:08 AM
Holset powered 420a
It has been boosted for a little over a month now. The turbo has no in/out play. My EGT's only hit 1400-1500 under boost. Im not sure how long it has been doing this, I can't see the smoke, you have to be driving behind me. But I believe that it has been doing this for a little while, it seems to be getting worse though. I will have some time next week to check everything out. Im still leaning toward the turbo because if I dont boost I dont get any smoke.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-15-2006, 03:19 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
A simple 5 min compression test could tell you alot. Rings that are *going* bad will most likely smoke under extreme pressure (under boost) but not while coming off. I'd say check the turbo.
95 Talon TSI AWD
97 Eclipse GST
Old 12-16-2006, 01:12 AM
jonnyboy9012's Avatar
jonnyboy9012 jonnyboy9012 is offline
Send a message via AIM to jonnyboy9012
Hey... i had the same problem when i turboed my PT (with a motor similar to the 420a... it is acutally a sub-division of that motor called the "EDZ"). The problem did turn out to be the turbo.I couldnt figure the damn thing out, i checked all the crankcase lines, compression checked... basically everything i could think of. I turned out to be the turbo seals on the inside, i bought a cheap ebay turbo (i know... i know, but i already got what is deserved and i was broke at the time) that lasted great for about 2 weeks, the outside of the turbo itself was of excellent quality but where the saved money was on the bearing housing, the seals where shot and it would blow oil. It blew oil because the seals had worn to allow tollerances to fall out of spec... i dont know how many thousands of an inch are supposed to be between the journal bearing and the shaft, but i know mine was enough to cause blowby. I still dont have an explination on why it did it when i lifted on the throttle, but it did... and the seals where the culprit. Hope this helps.
Current Cars and Specs:
1972 chevrolet nova
402 Chevy Big Block
Borg Warner 5 speed trans.
Future Mods:
Procharger super charger
NOS Carb Plate Nitrous System (150 Shot)
Hoosier pro street radials
2005 Chrysler PT Cruiser 2.4 Liter (soon to be traded for 96 TSI AWD)
Garret T04-E Turbo
"Quick Flow" Air Filter
Complete Custom Setup
6psi@219whp
URC Member #1
Old 12-18-2006, 05:25 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
your egt is 1400-1500 under boost? damn. i dont know if naturally-NA motors that are turbo'd run hotter than a naturally turbo car, but i know on my car, under full boost of like 20-21psi, my egt is about 1250-1300 and stays.
maybe your car is running lean. that could be heating up your engine and causing rings and whatever else to heat up really bad, and possibly fail. i dunno just my two cents. i cant really say a lot because i dont know much about 420a-turbo.
my 91 gs turbo puffed out a little blue smoke when i boosted. it was all stock. when i put another stock turbo on, the smoke stopped. maybe it is just your turbo. hope you figure it out, smoke and nasty smell coming out of the exhaust is embarrassing!
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 12-19-2006, 07:28 AM
Mikelb's Avatar
ok... I'm not sure here... but I'm gonna say with EGTs that high, I think you're running lean... bump up your fuel compensation a little, and see those drop... I'm not certain on this, but that's why I gave everyone else some time to look and see what they thought.
I am definitely leaning towards the seals in the turbo... from what I've read, it looks to be the culprit... I think that the bearings are allowing it enough shaftplay that once you come out of boost it blows the oil by and comes out the exhaust side...
Old 12-19-2006, 09:38 AM
Holset powered 420a
I beleive that the EGT are fine, when the motor was n/a they would sit at 1400 @ 70mph. 1500 if the a/c was on. Also remember that the 420a has higher compression than the 4g63. I am going to try and get the compression tested this week. The motor is suppose to be hot right?
EDIT - I searched around on 2gnt for a little while and found out that on a good tuned motor they should be 1500-1600. So I am running a little bit rich.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-19-2006, 06:30 PM
I wouldn't lean it out anymore though, just to be safe. Do you have a different turbo you can put on and test?
95 Talon TSI AWD
97 Eclipse GST
Old 12-19-2006, 10:03 PM
Holset powered 420a
No, thats the only turbo I have. I can't lean the fuel out anymore, actually I can't adjust the fuel at all. Im just gonna run the turbo and see how long it takes to breaks. I might even put a 16g on it. Would there be any noticeble difference in performance?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-20-2006, 01:16 AM
If your going to have the turbo on their for longer than a couple weeks try some heavier weight oil... it helped mine stop smoking so bad for a little bit, but it still smoked like Ron White on a welcome back tour. And it will get worse very quickly so keep an eye on oil levels. I finally said enough is enough when a cop pulled me over and gave me a fix-it ticket for the sight and smell comin' out my exhaust. Good luck.
1972 chevrolet nova
402 Chevy Big Block
Future Mods:
Garret T04-E Turbo
6psi@219whp
URC Member #1
Old 12-20-2006, 06:53 AM
Holset powered 420a
Well damn, I just hope it will last a couple more months. Im going to the track tonight so we will see what happens. Hopefully it wont blow up
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-20-2006, 07:18 AM
Mikelb's Avatar
eww.... I wouldn't suggest running a car hard unless you have its problems fixed first, b/c then it will develop new ones...
You don't need to run it hard until you know that it's really the turbo and not the motor, or that it could be running lean...
