Old 09-19-2002, 06:43 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
What's the best tranny for a d-series?
Hey all.
So, pretty soon, I'll be getting my D16Y8 engine, and it's looking like I might (possibly) need to get a new transmission as well. So, I was wondering what the best one to swap in would be?
Right now, I've got an Si tranny, and I really like it, but I'm curious if there's one out there with better gearing or something, or should I just rebuild the one I've got?
Thanks.
Old 09-19-2002, 07:14 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
im no d series expert...but i would think that the best trans for that motor would be the 6G 96-00 EX trans. that is the trans that that motor was originally bolted to. The d16y8 motor revs higher than the d16a6, so im assuming that the gearing in the EX trans would be better for that motor. honda must've known what they were doin when they made the trans for the EX motor. the si trans (L3 i think) has good gearing-tho (for that motor). i myself would probably just keep the si trans(assuming that there's nothing wrong with it..and because im a poor ass)....because then i'd know that my axels would for sure work with it. not sure if your si axels would work with the tranny for the Y8 (wish i knew the code) tho.
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 09-19-2002, 07:17 PM
91zc 91zc is offline
Unless you want to convert to a hydraulically actuated clutch setup, I would stay with a 4g transmission...ie 88-91 Si, Dx, Hf, STD, ZC.
91 civic 4dr
b16a
14.8@94
Old 09-19-2002, 07:28 PM
Fishcat37's Avatar
oh ya.....completely forgot that your car has a cable trans....duh.... heheh maybe i should go to bed early tonight definitely forget the 6G EX trans.......you don't want to mess around with installing the the fluid reservoir and the clutch master cylinder, etc. keep your si trans...if it's bad....rebuild it...or get another one...junkyards usually have one or two decent ones (at least around here).
Appearance Mods:
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-MSD SCI-L ignition
Interior Mod
Former Cars
'94 Integra GS-R
'96 Camaro
Old 09-19-2002, 07:51 PM
ci5ic's Avatar
Cool. Thanks guys, that was the info I was looking for. Guess I'll either rebuild my tranny or find another 4G Si one.
Old 09-19-2002, 09:54 PM
Fishcat37's Avatar
no problem, dude
Appearance Mods:
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-MSD SCI-L ignition
Interior Mod
Former Cars
'94 Integra GS-R
'96 Camaro
Old 09-19-2002, 10:09 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
hey mike...i was once told the 88-91 EX tranny has a taller final drive. i don't have any factual proof. maybe you can call honda and find out?
otherwise, stick with the a6
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-19-2002, 10:34 PM
ci5ic's Avatar
Cool. I'll give them a call.
I'm so excited about getting my Y8 after seeing yours!!! Maybe I will be able to get it in before it gets too cold out.
Old 09-19-2002, 11:16 PM
amy@af's Avatar
too bad you don't live closer...we could have a swap party... have that bad boy dropped in 9 hrs or less
Old 09-19-2002, 11:43 PM
dx_tuner's Avatar
dx_tuner dx_tuner is offline
The Si transmission is the best choice available. Both the Si and DX transmission bolts right up and keeps the install simple. The DX transmission will sacrifice performance for better fuel mileage and lower freeway rpms. The ZC tranmission has a close ratio 1-5th gear, but a long final drive, making the best transmission still the US Si. For the ultimate acceleration make a Si/ZC hybrid transmission, by taking the Si final drive and put it in the ZC transmission. Or you can do it the other way around, ZC 1-5 in a Si transmission case. Either way, expect 80mph to turn 4300 rpms. However, the ZC transmission requires you to use ZC or 90-91 Integra axles, and a ZC or 86-89 Integra intermediate shaft. Because these axles are equal length, many users report a reduction in torque steer.
1989 Honda Civic HB DOHC VTEC 1.8L 07 2005
WWW.HONDA-TECH.COM
Old 09-30-2002, 01:20 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Hey, i know this is an old post, but I just got a new tranny cause i fuked up my old one, I got a ZC tranny froma friend who just swapped out a ZC and put in a b18c1 (GSR) motor. He sold his ZC, but had the tranny, he has brand new gears in it and a Si final drive, so i got a kick ass Hybrid Tranny cause its got new gears, Si final, and i got it for 200 bucks! That and my Exedy clutch work great together! OH i love this tranny!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 10-02-2002, 12:06 AM
aZn*RaCeR*cHiCk's Avatar
aZn*RaCeR*cHiCk aZn*RaCeR*cHiCk is offline
Send a message via AIM to aZn*RaCeR*cHiCk
use a freaking 88-91 si tranny or a good zc. there are two different trannies for the zc. one has shorter gears. in my opion,...... GET A DAMB B SERIES SWAP. quiting play around.
2001 pReLuDe
1991 cRx Si
Old 10-02-2002, 12:11 AM
MyFirst4G's Avatar
Werd, but i need a lil more ching ching before i go with the bling bling!
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 10-02-2002, 01:18 AM
GTA's Avatar
GTA GTA is offline
Whee..
thats no way to put it. He is doing a swap, a SOHC Vtec swap. Not everybody wants a damn B-Series!! Just because its a D-series doesn't make it a crappy swap, so grow up.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 10-02-2002, 11:20 AM
amy@af's Avatar
don't you mean: nOt EvErYbOdY wAnTs A dAmN b-SeRiEs.
it's all good greg. if a b series is the only way she knows how to get to 160hp, then lets all pray one day somebody takes the time to give her a clue that there are other swaps out there....
12 SECD-SERIES
ami
