1999 Silverado "no headlights", help pls.
Pulled into drive at home and turned truck off, all was working fine. Then came back out 5 min. later and started truck everything works but no headlights incl. h-beams. Have basic manual and tested dash light switch, all fuses, pwr to headlamps ?able, both wires on L/R low beam connectors test out at 11.8vdc. DRL's do work fine as well as running Lts. and fog Lts.
Any help would be appreciated. Tks.
Wisdom is the culmination of repatition until it is right.
Re: 1999 Silverado "no headlights", help pls.
Not going to be much help I think. But I had a problem with my LBEC fuse blowing under the hood. I can't remember which one 1 or 2 and it was tied to my rear lights. The problem ended up being a ground located next to my parking brake. It was one of those problems that GM fixes if u bring it in. I was told people who use their parking brake all the time had the problem with ground. My truck is a 2004 1500. Hope this helps.
Bill |
Great- thanks for the tip. I chk'd some of the grnds I'll chk this one.
LEt us know when you find out what it is please.
Bill |
Found out the problem. Found two melted wires under the steering collum, they wer not bad enough to catch fire but had melted enough to deform the connector forcing the ground to the HI/LO switch to become disconnected. After some reengineering to make it safe all works fine. Ironically the headlights seem to brighter. In the process the assoc. relays, dimmer, and headlight switch all checked out good. Tks all for the input, Rick.
I have a very similar problem with my 1993 Silverado 1500....no dashboard or tail lights. I've checked the fuses near the steering column and they all look ok. Is there another bank of fuses that I don't know about? (I don't have the owner's manual.)
The discussion about "grounding wires" was very confusing to me. If that's the problem, then I don't even know where to start! |
I have a 2004 and there is a set of fuses under the hood next to the battery under a cover about 12 inches by 12 inches. I had the problem with the LBEC1 or LBEC2 fuse located there and it did affect my tail lights. The ground that was the culprit I never saw. But according to the dealer it was near the emergency brake pedal.
good luck Bill |
Hope this helps. Rick. :-)
