Old 12-14-2006, 07:30 PM
streetside69 streetside69 is offline
94 pa rough idle
the car idles rough all the time at idle but when cruising the car seems to run fine also when i come to a stop after cruising it idles rough and then bogs down lights dim oil pressure drops voltmeter drops then kicks back up and just idles rough again i changed the altenator spark plugs wires coil packs fuel filter cleaned battery terminals i have no idea what else to do
Old 12-14-2006, 08:00 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 94 pa rough idle
Any codes?
Old 12-17-2006, 06:00 PM
TGARST TGARST is offline
I would remove and clean the T-Body, paying special attention to the IAC Valve. I would also clean the MAF sensor.
Tim
Old 01-23-2007, 09:28 PM
thanks tried it and still did nothing no worries though my lady is getting a new car not my problem anymore thanks alot though i truly appreciate your help
