| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Got a couple of things.
I got a 97 RS (420a) 5 speed, tranny is leaking a little. Think its a bad seal but will fix later.
My 1st question is how do I check to see if the tranny fluid is low? Where is the plug to fill it up at.(Pictures would help) 2nd thing is i pulled the spark plugs out and the cyclinder they sit in (not in the piston cyclinder) there was this shit brown oil(I think) well anyway would that be from someone spilling oil all over the valve cover and it sepping in or would it be a bad valve cover gasket? 3rd thing is when its idleing it makes a squeaking noise (well not really but thats the closet i can put it in words) then when i put the clucth in the noise stops.(I havent had a chance to drive it yet because i have no plates and no insurance on it yet cuz i just did t belt and water pump replacement). Any info would help.Thanks. |
Re: Got a couple of things.
The squeek might be from the throwout bearing, it could be going bad or in need of grease.
To check the tranny fluid, there is a bolt on the front side of the tranny where you fill it. You take it out and put your finger in the hole and the fluid should be right to the bottom of the hole.
-Brian
throw out bearing is bad. No doubt.
Also blackcrow covered the other questions perfect
Current Cars 2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod. 2003 Grand AM GT - official beater car for the winter lol ---------------------------------------------------- 95 TSI AWD [email protected] (T-25) Now fully Modded engine with 3,560 miles on it.SOLD |
I agree that the throwout bearing is bad. When mine went bad last month, my mechanic said it was the worst he had ever seen. It was oval in shape and turned blue from the heat also there was only about 3 of the little balls in the bearing left!!!
LoL, ok thanks guys. Mine must be pretty bad too cuz its pretty loud.
Also about the oil or brown shit in the spark plug holes do u think its a bad gasket or that som1 spilt a shit load of oil all over it and left it sit for awhile. Cuz there was some in each of the holes. |
Dont listen to them, its not your throw out bearing. If the noise goes away when you push the clutch pedel in its something else because the only time the throwout bearing it turning is when you have the clutch pushed it
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
The oil fill hole is on the side of the tranny. You have to take off the wheel and splash guard. It's a little rubber plug towards the top of the side, the oil level should be at the very bottom of the hole. As for the brownish shit, it's most likely oil. Get the most of it out that you can, change plugs, and clean up the wires.
Not necessarily.
My throw out bearing on my cobra went bad and when I was driving around it used to sound like I had rocks rolling around in my transmission.
1991 GSX 2.3 Stroker |
your pilot bearing probably was out to then, unless your tob fell apart in the bell housing
It was pretty funny, but it's to be expected, I drove the piss out of the car.
-Brian
if oil is getting into your spark plug wells, you should probably change out the valve cover gasket... the gasket comes as a set with the spark plug grommets, they have probably dried up and are leaking...
I also suggest using RTV sealant to hold them in place while putting the VC back on (from experience... that made it hard to sell the car)...
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
-Brian
Yes its the bearing that supports the input shaft
