Old 12-14-2006, 02:12 PM
Gm crazzy Gm crazzy is offline
Send a message via Yahoo to Gm crazzy
rear wiper
I have a 99 jimmy slt 4x4 4dr and the rear wiper for some reson will only move about 12 in. and then get stuck. Any ideas
Old 12-14-2006, 09:52 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: rear wiper
does it make any noise when it gets stuck, like a loud grinding noise? if it does, the internal gears of the wiper motor are worn and the motor needs to be replaced.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 12-15-2006, 02:25 AM
Re: rear wiper
no it doesn't make any noise and if i lift the wiper off the glass it works just like its supoust to.(no noise,grinding or binding)
Old 12-15-2006, 02:26 AM
Re: rear wiper
sorry for the typos
Old 04-17-2007, 03:49 AM
hootymo's Avatar
hootymo hootymo is offline
Send a message via AIM to hootymo
Re: rear wiper
same thing's happening to my '99... any ideas?
-Ryan
'99 Blazer LT
Old 04-17-2007, 03:02 PM
MDY MDY is offline
Re: rear wiper
My wifes 99 Envoy did the same thing. There is a nice write up on removal in the How To section. What I did was remove motor/cover and drill through the housing and install a thin bolt with washers to hold the gears together (the problem is that there is a round compression washer holding the gears together, pops off letting the gears go nuts). If the motor works, spend an hour of your time instead of a new motor.
Hope this works for you.
