Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-14-2006, 12:29 PM
zeihert zeihert is offline
Thumbs up 96 ciera
My 1996 ciera 3.1 motor starts great but stays up on high idle even when warm unless I turn the car off and restart it then it runs fine.It only does this when its cold out.I need help on this one please.I think its the computer itself now.I can get a used one for around 30.00 bucks
Old 12-14-2006, 03:22 PM
maxwedge maxwedge is offline
A990 racer
Re: 96 ciera
Get it on a scanner for coolant temp sensor readings, clean the iac and passages also.
Old 12-18-2006, 02:05 PM
Re: 96 ciera
Need more ideas on this one.Maybe tps is bad,but ive got no check engine light coming on at all.You would think that it would if something was bad???
Old 12-18-2006, 03:50 PM
A990 racer
Re: 96 ciera
Have you done a full scan and looked at the tps and iac readings?
Old 01-11-2007, 12:15 PM
Re: 96 ciera
Yes I had a full scan done at a dealer and nothing came up of course this was when the engine was warm and it only acts up when its cold.After it warms up I need to turn the ignition off and restart the car to bring the idle down.Im stumped!!!!!!!!!!!
Old 01-11-2007, 05:08 PM
caddyman379 caddyman379 is offline
Re: 96 ciera
I doubt this will work, but it won't hurt. I would disconnect the negative battery cable for maybe half an hour. This will clear the ICM. Then, allow the vehicle to idle from a cold start to warm and let run for 15 minutes at idle. Then, drive the vehicle invarying condtions so it learns your driving habits. This would be highway, city, stop-and-go, etc.
If i'm wrong please feel free to correct me.
Old 01-12-2007, 06:52 AM
Re: 96 ciera
The idle wont come down till the car has been driven at least 30 to 50 miles when its good and warmed up.I did what you said and there was no change it went up to high idle right away.I think it might be the computer??????????
Old 01-12-2007, 08:34 PM
Re: 96 ciera
sorry, let me rephrase that: Disconnect the negative battery cable. This will reset the ECM, which controls the idle among other things. If the idle is somewhat normal, then follow the steps I gave you. If not, then stop the engine.
A high idle is normal when cold, but not extremely high.
What have you done on cars? Tuneups? Im curious how mechanically inclined you are
Old 01-23-2007, 02:02 PM
Re: 96 ciera
I think its the computer????????????
