Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-14-2006, 06:38 AM
usat212 usat212 is offline
under carriage replacement (help please)
My son has a 1992 olds cutlass, He went around a curve to fast and ended up in a ditch. The only damage we see is the strut, the control arm(I think that's the name) and the under carriage (or sub fraim). We were wanting to know if the under carriage from a lumina will work? Or if another cars under carriage will work. Any pointers on replacing any of these parts will be GREATLY appreciated. The damage was done on the drivers side if that helps anyone
Old 12-14-2006, 10:48 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: under carriage replacement (help please)
SUSP SUBFRAME, Part #:12369168
The subframe from a 90-94 Chevy Lumina is supposed to be the same. Also, possibly the 88-96 Buick Regal. The GM part numbers are the same.
The key to replacing a subframe will be to have engine and tranny hoist/lift capability to hold them while the subframe is dropped from below. Replacing lower control arms and struts is the easy part.
Timeslip 08/12/06
AF Community Guidelines
Old 12-15-2006, 06:11 AM
thanks for the reply, I'll see what I can find. I hope your right about the strut and control arm being easy to place. Thanks
Old 12-16-2006, 07:30 PM
Ian Szgatti's Avatar
Ian Szgatti Ian Szgatti is offline
he is right about that... remove the stabilizer bar and then pop out the ball-joint and then undo the two control arm bolts. While you remove that one, you should do the other one and install some brand new bushings. That makes for a comfortable ride.
Old 12-26-2006, 12:08 PM
chevymut chevymut is offline
i would also look into it and make sure there is no frame/subframe /or bent body damage .i would hate to see u put that much workinto it and discover alignment problems because of that being overlooked.. goodluck
Old 12-26-2006, 02:28 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
I would also say whether the body/frame is damaged or not you will need to take it to a frame shop that can aligned/straighten the car correctly.
If not, you might be in for a sideways(dog tracking) ride.
Good Luck !
1999 Grand Am SS 3.4 OHV
Old 03-05-2008, 06:08 AM
way way is offline
I know this is an older thread but figured since it's related it would help anyone searching.
I have a 91 Ciera with the 2.5L automatic that the k-frame rotted out on the front passenger side. I have located one at a j/y. I also have to replace the TCC solenoid and I was wondering how to combine the two jobs? Will I be able to reach the solenoid with the frame dropped?
Thanks
96 Geo Metro H/B 1.0 L, 5 sp, A/C 103K miles (165,762 KM)
96 Geo Metro LSi 1.0 L, 5 sp, 1025 miles (1649 KM)
91 Olds Ciera 2.5L 2 DR Auto
Old 03-05-2008, 07:52 AM
BNaylor's Avatar
Thanks
Sorry for old threads the following guidelines must be followed below. Best to start a new thread and provide a link to an older thread that may be helpful or relevant. This thread has been closed.
http://www.automotiveforums.com/vbul...d.php?t=891500
Timeslip 08/12/06
Closed Thread
