Old 12-14-2006, 01:11 AM
arodg25's Avatar
arodg25 arodg25 is offline
best time to activate vtec
i'd like hear opinions on the best time to activate vtec for fastest acceleration.
thanks.
Old 12-14-2006, 01:13 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: best time to activate vtec
probably where it is stock....i'm pretty sure that they didn't just put it at a certain RPM on a whim...
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-14-2006, 02:45 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Actually it is just below the stock point, having a more fluid smoother activation is better. When you feel that little boost in power, it is because the engine has already peaked in power and the vtec activation has basically given it a different power band. In reality, if you were to not feel it at all then it would be better.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 12-14-2006, 03:18 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
thanks.
It's going to be different for EVERY engine. It depends on bore/stroke/cams duration/cams lift/head port size/head port shape/exhaust diameter/intake manifold runner length/intake manifold port size/intake pipe diameter/intake pipe length/air filter/muffler size/muffler design/catalytic converter/header runner length/header collector point/injectors/etc.
Get it?
The best spot is usually somewhere between 4000 and 8000 RPM's. You have to dyno tune your car to find out.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-14-2006, 09:02 AM
Schister66's Avatar
AF -Advisor
On my GSR, it engages at 4400 (and i have no IAB function) which was the best point according to my tuner, because it coincides with the spool time on my turbo......that was on my old setup....
Old 12-14-2006, 05:15 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
i swicth between 4400 and 5500.
-tony-
2000 honda s2000
