Old 12-13-2006, 11:34 PM
Divorce Court Dan Divorce Court Dan is offline
Send a message via AIM to Divorce Court Dan
Two Questions
I was wondering where the starter enable relay is located on a 95 Buick Park Ave, and also what are supposed to be the correct resistance values on the ignition keys? Thanks
Old 12-14-2006, 12:01 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Arrow Re: Two Questions
The starter enable relay is buried deep in the dash behind the instrument cluster. You will need to a contortionist, in order to find it. You have 15 standard resistor keys, the values of which can be found here.
Just wondering, did your "X" flush your keys down the toilet?
Old 12-14-2006, 06:53 AM
Re: Two Questions
HA! HA! HA! THATS A GOOD ONE! No, not quite. I was given that nickname. Thanks for that info. My key values are 1127 and 1123. I was thrown off by the decimal on the voltmeter, because it looks like the values are without decimals on the chart.
Old 12-14-2006, 01:35 PM
imidazol97 imidazol97 is offline
AF -Advisor
Re: Two Questions
Are you having a problem with the VATS system or starting the car?
