Old 12-13-2006, 11:21 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
no start..
do i need to have the srs aig bag computer pluged in to let my car turn over??
first shot with the jdm swap.. and not even a sound...
Old 12-14-2006, 09:26 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: no start..
when you turn the key, what happens? any noises?
i assume you haven't run those wires to the back, right?
did you get my PM?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-14-2006, 12:25 PM
Igovert500's Avatar
blue + red light magnet
Re: no start..
Are you getting fuel, spark?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-14-2006, 01:36 PM
jason_bet's Avatar
Re: no start..
i wired up what i belive to be the fuel pump.. 5 wires?? if they are the same color codes anyways.. and there was the brown cover over them.. any way i got it to crank over fine.. but no spark and no fuel.. when i turn the key on the fuel pump doesnt click on at all.. not even for a secend.. I have the feeling this is going to take a while.. haha
Old 12-14-2006, 02:32 PM
Igovert500's Avatar
Re: no start..
eci fuse plugged in? CAS working?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-14-2006, 05:35 PM
Linebckr49's Avatar
Re: no start..
you should prime the oil and fuel systems before you try to start it.
oil is easy, simply unplug the CAS, and turn the engine over a few times.
as for the fuel, well you would need a datalogger to activate the fuel pump to fill the lines with fuel. i'm not aware of any other way to prime the fuel system. so you'll just have to keep cranking until fuel fills the lines and becomes pressurized.
93 3000GT base
Old 12-14-2006, 08:49 PM
jason_bet's Avatar
Re: no start..
Well my CAS should be working fine.. its plugged in.. ECI...( electric control ignition?? ) all the fuses are in and look in good shape i will test them tomorrow.. any other ideas? so wait.. does are fuel pump not kick on when you turn the key to the on position? like a self prime system most cars have?? this is new to me.. are there any JDM wire diagrams any of you have seen? I have lots more questions with most likely simple solutions that i am just spaceing or not aware of i will post as i get more and more into this thing.. i want to have the car running by or at least on sunday
Old 12-15-2006, 01:09 AM
jason_bet's Avatar
Re: no start..
Is there a fuel cut out switch.. that might have to be manualy switched back? similar to the ones that if you get in a wreack it shuts off the fuel?
Old 12-16-2006, 05:37 PM
jason_bet's Avatar
Re: no start..
HELL YEA!!!! it started up.. still no fuel but it has spark.. nothing a can of either can help haha ok.. now its just the easy part.. fuel.. kinda.. any ideas would be great thanks!
Jason
Old 12-16-2006, 05:57 PM
Igovert500's Avatar
Re: no start..
Check for voltage at the pump
check for voltage at the injectors
Test MFI relay
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-19-2006, 09:39 PM
jason_bet's Avatar
Re: no start..
ok!! she started up and sounds great.. i let her idle for about 20 minuts.. the idle slowly went down and down to a more normal one.. i have 2 questions now.. is there a specail way to fill your power steering fluid?? i put a quart and 1 half in and it stoped taking any more in but it is squeeling like a bitch!! and second.. after 20 minuts i looked at my guages.. that i didnt think worked.. and my temp guage was working and showed i was just perfect temp.. and then the oil guage said i had no oil pressure.. so i shot it off .. now i dont think i would have been able to run for 20 minuts without oil.. so i am almost positive that it is just my sensor or somthing.. any thoughts??
Old 12-19-2006, 10:04 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: no start..
Haha I would be willing to bet a lot of money that it is either not hooked up right or is broken. They are very notorious for going out on our cars. My car's oil pressure guage almost always reads "0"
Old 12-19-2006, 10:31 PM
jason_bet's Avatar
Re: no start..
haha yeah.. im just a dump ass.. i't didnt have a good conection on the oil sending unit...
Old 12-19-2006, 11:07 PM
bryan_bigd's Avatar
bryan_bigd bryan_bigd is offline
Re: no start..
hey buddy when are you gonna put the movie of the car running on here. give me a call. did you put the rest of it together yet
1995 talon tsi 10-26lbs of boost boost controller k&n intake 550cc injectors 255 fuel pump ported head 3 angle valve job hks metal head gasket arp head studs racing manifold evo3 16g ported turbo 34mm wastegate 3in turbo back exhaust no cat act 2600 clutch 7.9 lbs fly aem 9.3 plug wires irradom plugs lowered 2 in camber correction all four wheels 2 3/4in upper intercooler pipe greddy rs BOV racing hard intake pipe apexi NEO fuel manigment system oh and it has the 6bolt motor
