Old 12-13-2006, 10:54 PM
berniescout berniescout is offline
engine ground strap 97 blazer?
is there a ground strap between the 4.3 w engine and the frame on a 97 blazer automatic? 2 or so years ago I had an intake manifold gasket done and wonder if the mechanic left off the ground strap or is there a rf suppression condenser somewhere that he may have leftoff? Ever since I have some ignition noise on the am radio. thanks.
Old 12-13-2006, 11:39 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: engine ground strap 97 blazer?
There should always be a grounding strap between the engine and the chassis of any given vehicle. On cars where this ground strap is damaged or missing, electric flow can occur between the driveshaft and transmission tailshaft housing - the slip joint here can cause noise in the radio, as well as electrolysis of the driveshaft and/or transmission output shaft bushing, as well as a sporadic chassis ground which comes with its own set of problems.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-14-2006, 12:21 AM
Jari's Avatar
Jari Jari is offline
Other end is back of right cylinder head and the other end is bolted to frame just above it.
Its a flat copper cable about 20mm x 3mm; 300mm long... (this is -98)
Old 12-17-2006, 09:22 PM
I have looked all over the engine for a ground strap, none found. checked out another 97 blazer and found none. checked out a 98 and there it was, passenger side at the rear of the engine. i did install a heavy "0" gauge ,fine straned battery cable from the neg. battery cable to the alternator bracket. i will install another heavy cable from the engine, probably from the same alternator bracket to the frame and see if i clear up my noise. my 97 does have a 10 gauge or so wire fron neg battery terminal to the frame rail near the battery. any comments from 97 owners????
Old 12-20-2006, 02:32 PM
yesterday i stopped at the local chevy dealer and asked about ground strap question. parts guy said there are 3 , one block to firewall, two coil to engine and didn't have time to look for the 3rd!!!! the service guy said he didn't have time to look! time for new dealer!!!!
Old 12-20-2006, 04:55 PM
someguy000001 someguy000001 is offline
Does the radio noise change to coincide with engine speed a-la possible alternator noise?
The easy things to check are the battery terminals (for corrosion). I would think the fat wire you hooked up would help with a bad ground?
I took a peek while under the hood of my '97 and have no obvious ground straps from the block..
