Old 12-13-2006, 08:31 PM
Bart8528 Bart8528 is offline
2000 Windstar ABS light
I have that intermittent ABS light problem. Keeping the fluid level high and having cleaned and measured the wheel sensors have helped a lot. I've read some posts about 'cleaning' the level sensor contacts. Can I remove the sensor without draining or losing the master cylinder fluid?
Old 12-14-2006, 08:35 AM
phil-l phil-l is offline
Re: 2000 Windstar ABS light
Probably not. But if you empty the master cylinder (a turkey baster with a short piece of tubing works great) - and immediately refill it with fresh fluid after your work is done *WITHOUT* pressing the brake pedal, you'll be fine (i.e., no opportunity for air bubbles to make it into the master cylinder or brake lines).
Of course, if you've already done this much work, it'd be a great time to bleed the brakes anyway (which is one of the early steps I recommend whenever tackling strange brake problems).
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
