1995 Silverado how to remove steering wheel w airbag?
I want to replace the MFC switch & wheel needs to come off.
Thanks |
Re: 1995 Silverado how to remove steering wheel w airbag?
Disable the sirs, disconnect battery for 10 minutes, use extreme caution here put the air bag away from the work area with the airbag facing up. Normal procedures after this.
Check this link, then on the same page look at the steering wheel removal selection. http://autozone.com/servlet/UiBroker...3d800880f8.jsp
Thanks for the tip. Factory GM manuals are clear as mud. I bought them with the car way back.
After all that the replacement MFC does not fix the blinkers shorting. Hazards work fine, no wiring appears damaged. Trailer tow plug has no effect, new bulbs all around. |
Sounds like a bad ground...
Mark Mcknight Elmvale Truck & 4x4 (705)-715-7867 Elmvale, Ontario 87 Mustang GT, 5.0L 5 spd, MSD ignition, BBK tubes, flowmasters, tri-ax shifter, 4.10 gears 69 Charger SE, stroked & poked 383,727 over 550rwhp 86 Chevy 2500 4x4 Plow truck, 350/TH400, 8ft fisher plow |
