Old 12-13-2006, 07:15 PM
sivic02's Avatar
sivic02 sivic02 is offline
Windows problems
So I started up the computer the other day and windows wouldnt start up it said that a file was missing in C:\WINDOWS\system32\config I cant remember exactly what it said but it suggested tossing in the windows cd and going to repair. I didnt have a cd with windows xp media center edition on it but I did have an old regular xp cd, it wouldnt repair it so I put the older version of windows on the computer, copied the files out of C:\WINDOWS\system32\config and replaced all the files on the messed up windows (i didnt see any files missing) and it works....kinda. There are a few glitches such as firefox is gone, i just recently got the media player working again, all of my old settings have been changed back to the factory settings.
Anyway, anyone have any idea as to what happened and what I can do to get all of my settings back to the way they used to be and have everything work the way it used to? I made a copy of all of the files before I replaced them. Any help would be great, thanks.
Here's to being single, seeing double, and sleeping triple
Old 12-13-2006, 08:37 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Windows problems
What settings are you talking about exactly? It sounds like you just installed a version of XP over a version of Media Center, so obviously all the basic stuff is going to change, but you should still have all your files. Just reinstall Firefox to fix that.
What did you try in the repair console that didn't work?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 12-13-2006, 08:43 PM
sivic02's Avatar
repair said there went any problems
there are just random things wrong like for example the windows games (solitare, pinball) and a few other random programs dont work like some engineering programs, CAD, just random stuff.
Old 12-14-2006, 09:38 AM
You can't just reinstall those programs?
As for the Windows games, go to the Add/Remove programs section in the Control Panel, remove them, restart the computer, and then re-add them. See if that works.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 12-14-2006, 04:58 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
When you installed XP over the top of MCE, it would have overwritten the Documents and Settings folder, so if you had any data stored in your old Windows Profiles (C:\Documents and Settings\%username%) it's probably long gone. About your only chance to get it back is data recovery software like GetDataBackforNTFS, but I don't like your chances.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 12-29-2006, 12:50 AM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
Winblows won't let you install over Winblows and still work right, will run into all kinds of conflicts, if it were me, I would backup all my important stuff and install a fresh copy of windows after a reformat. As far as it deleting files from your documents, it shouldn't have, seeing as you still have your programs and things on it.
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 01-04-2007, 10:51 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
ive had some similar problems. i have an hp pavilion a1514n with XP media center 05. i was getting many program errors and the computer would restart randomly. then i did a disk cleanup and then windows would not boot. did system restore twice and now every time i open a program, i get a windows installer error so the only program i can use is the internet. i also can't install or uninstall any software or hardware, still get program errors, and still shuts down randomly. i got a message one time that says it might be an error with the video card and to download an update. well i tried but i get that windows installer error so i can't get the update to possibly fix the problems. anyone have some other suggestions on a possible fix? if i can't fix it myself im cashin in on the warrenty.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 01-04-2007, 11:46 PM
You could reformat and try a fresh install...just back up all your documents on a flash drive or external.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 01-05-2007, 03:15 PM
ZL1power69's Avatar
GM S-Series Mod
did a system recovery twice which reformats the hard drive each time. it did not come with a windows recovery disc.
Low 11 sec sleeper
My Cardomain
Old 01-05-2007, 11:57 PM
System recovery isn't quite the same. I will bet if you do a real format and clean install, it will take care of the problem. If you don't have any operating system disks, borrow a friend's and use your serial key during the install.
'92 3000gt SL
Zoom Stage 1 Clutch
