Old 12-13-2006, 12:03 PM
panther_wildcat panther_wildcat is offline
Re: Cam sensor code
i am working on a 95 buick that is doing similar things the cam error and the cam signal cirrcit. i have tested everything but still i have not gotten it to run right. we have put in a new cam sensor, crank sensor, PCM, and a ICM. it still comes back to the same code PO431 and PO342 and i have visualy and with a DMM check the wires and the links to the cam and the crank. if you have any idea what is going on i could use the help.
thank you.
Old 12-13-2006, 02:43 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Cam sensor code
Have you checked the cam gear magnet on your car?
Cam magnet replacement
BTW: Welcome to AF! If you will notice, I started this new thread for you using your post in an older thread. The following links will help you better understand how AF works. Thank you in advance for your cooperation.
Posting in closed or outdated threads - LeSabre
Community Guidelines
Search Forums
Post New Thread - LeSabre
Old 12-13-2006, 05:19 PM
Re: Cam sensor code
thank you and i hope i can bring some knoledge to the table.
i looked to see if the magnet was there. the magnet is in one pice and still magnitized.
i just took it out for a road test and i am still geting the codes but i am not getting any cam errors trough gennises.
i have gone back and looked at all the wiring and the 8 pin plug that is under the passenger side carpet.
that was clean as a wistel.
i realy dont know what to think on this.
Old 12-14-2006, 04:51 PM
Bassasasin Bassasasin is offline
Re: Cam sensor code
Looks like either a wiring problem or your down to trying a new ECM.
Good Luck
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
