Old 12-13-2006, 01:58 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Replaced water pump gaskets today
I replaced the water pump gaskets today because of a leak . Fairly easy job . Is it common to have a leak there . Any of you had this ? My is only 4 years old . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 12-13-2006, 09:51 PM
ontheedge02 ontheedge02 is offline
Re: Replaced water pump gaskets today
I bought a used 2001 with a 5.3L about a month ago, and had to do the same thing. Water pump gaskets, gas cap, fuel pressure regulator and now if I could get rid of the famous "clunk", I will be all set. I guess some people's definition of "works great" is different than mine. Oh well, I'm just glad I haven't found anything major "yet".
Old 12-14-2006, 04:44 AM
Rmbodie's Avatar
This was the only thing I have had to do that was trouble. Everything else was just upgrading . Tires,wheels , shocks , brakes, battery, plugs. Speakers are next. The water pump is only torgued down to 133 inch/pounds. No wonder they leaked.Rob
2005 Grand Prix.
Old 12-16-2006, 09:43 AM
Rmbodie, you might want to double check those torque specs on you water pump. Mine said to tighten down to 11ft lbs (132 in lbs) the first time around, then go to 22 ft lbs (264 in lbs) on the second pass. I'm assuming that you were working on you 5.3 litre. Good Luck!
Old 12-20-2006, 04:49 AM
Rmbodie's Avatar
My haynes book listed 133in/lb , then 22 ? , no digits after the 22 . It just did not feel tight enough then either. I think I will retorque them before I leak again . Rob
2005 Grand Prix.
Old 12-20-2006, 09:30 AM
guumbah's Avatar
guumbah guumbah is offline
I've seen a guy over-torque these bolts and warp the casing. Then it REALLY leaks.
2002 5.3l - Quadrasteer
lose (lüz): v - to suffer deprivation of : part with especially in an unforeseen or accidental manner
loose (lüs): adj - not rigidly fastened or securely attached
