Old 12-12-2006, 11:31 PM
paxfam1 paxfam1 is offline
Tune Up
I got a 1998 Blazer 4.3 4wd. I want to do a tune up to try to improve gas mileage.
I want to do cap, rotor, plugs, wires, pcv valve, fuel filter, air filter, and a oil change.
Im gonna go to autozone tomoro, and I was woundering what kind of plugs I should by? I think platinums are in it right now, but im not sure if thats the best for it or not? Let me know what you all think........Also how do you remove the rotor?
paxfam
Old 12-12-2006, 11:54 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Tune Up
only use ac delco platinum plugs #41-932 gaped to .060. the cap and rotor are held on by torx screws (T-15 if i recall).
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 12-13-2006, 04:11 AM
Cloud Strife Cloud Strife is offline
Re: Tune Up
Yes they are T-15 screws. Be sure you do use that type of driver or you will strip the heads of the screws.
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
Old 12-13-2006, 08:52 AM
Re: Tune Up
Okay, I will get the ac delco platinum plugs #41-932 if thats whats gonna perform best in my truck......Anything else I can do to give it little better gas milage besides the things I said I was gonna put on it!
thanks paxfam
Old 12-13-2006, 04:50 PM
muddog321 muddog321 is offline
AF -Advisor
Re: Tune Up
Do not buy a cap and rotor at Autozone - they sell Wells and 2 have crapped on me after 20k miles. Get a Delco at the dealer or online. Depending on gears and driving habits with AC off between 16 city and 21 highway is about it. Clean air filter and MAF help.
Old 12-13-2006, 05:11 PM
ZL1power69's Avatar
GM S-Series Mod
Re: Tune Up
paxfam1, read the thread below for other things to do for better economy;
http://www.automotiveforums.com/vbul...d.php?t=453370
Low 11 sec sleeper
My Cardomain
Old 12-14-2006, 08:25 AM
Re: Tune Up
Hi, are there any other poeople that have had a bad experience with the wells rotor and cap. Thats all autozone has and thats the only parts store near by. Also---How do you clean the MAF Sensor? Also would cleaning the egr improve fuel econonmy, I am just looking to get this thing fully tuned, seems how I brought it back from the dead from sitting for a year and half. Last question is it normal to have spungy brakes. It sat for a year and now the brakes are very spungy.
Let me know
paxfam
Old 12-14-2006, 09:22 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Tune Up
Let me know
paxfam
Dealer OEM type parts only hurt one time. Use only ACDelco parts for it.
That after market stuff will hurt many time.
MT
Old 12-14-2006, 04:23 PM
ZL1power69's Avatar
GM S-Series Mod
Re: Tune Up
use brake cleaner or CRC's MAF sensor cleaner and a soft toothbrush to clean the sensor. if the egr is clogged, cleaning it would probably help with fuel economy.
Low 11 sec sleeper
My Cardomain
Old 12-14-2006, 10:23 PM
Blind's Avatar
Blind Blind is offline
Re: Tune Up
it sounds like the brake fluid needs to be flushed/bled.
if you have a power bleeder, do that, if you dont have one, get one!
I love my motive pressure bleeder, can flush/bleed entire brake fluid in 15 mins, I do it to all of my cars once a year.
also, you can buy all ac delco parts online at great prices (usually much better than dealer, and comparable to crap at autozone) from www.rockauto.com
1989 Mustang LX Coupe - ex 2.3/a4ld - 5.0/t5 conversion...with boost.
1991 Mustang LX Convertable - 5.0/AOD...stock
2001 Blazer LT 4x4 4dr
1980 BMW 320is beater
Old 12-14-2006, 11:15 PM
Re: Tune Up
Okay, got the brakes working by bleading them, and I ordered acdelco cap, rotor, fuel filter, pcv valve, air filter, and 6 plugs. Only last thing I could think of doing was checkin the trannsmission fluid. Sure enough fluids barely registering on the dip stick with the tranny warm. I was woundering how much it will take to get it back up to normal. Right now its only about 1/8" on the dipstick.
thanks paxfam
Old 12-14-2006, 11:35 PM
ZL1power69's Avatar
GM S-Series Mod
Re: Tune Up
with the engine warm, grab some tranny fluid, add a small amount, then go through all the gears and recheck the dip stick. repeat until the fluid level is in the upper portion of the safe zone on the dip stick.
Low 11 sec sleeper
My Cardomain
Old 12-14-2006, 11:56 PM
Re: Tune Up
Yea, I no how to do that. I was just woundering if its gonna take a quart of atf or 3 quarts. I just wanted to no how much to buy.
Old 12-15-2006, 12:01 AM
ZL1power69's Avatar
GM S-Series Mod
Re: Tune Up
it should not take much, but get a quart or 2 just to be safe. i had to add about a quart on my old 95 when the fluid barely showed up on the dipstick.
Low 11 sec sleeper
My Cardomain
Old 12-15-2006, 09:20 PM
Re: Tune Up
wow, I dumped 1 1/4 quarts into that baby..............It seems like its shifting smoother......
One other thing im noticing is when I start it up it runs really rough for a few seconds then it idles perfect. On most vechiles I have noticed you start it and the rpms go up to like 2000 and then come back down. This is starting and rpms are at like 250 and then it goes up and smoothes out......What could this be?
