Old 12-12-2006, 08:57 PM
sinfull90 sinfull90 is offline
Send a message via MSN to sinfull90
changing out your front diff for another
has anyone tried to put a selectable locker in the front of their silverado? i'm trying to come up with an idea to sacrifice some cushy ride for some off-road capibility. here's my idea: take a center section out of whatever, we'll say a dana 44, use the idea of the original front diff and fab up some small axle shafts with the spline matching whatever selectable diff you decide to use. so the shafts would consist of a stub with splines on one end and a drive flange on the other end, then drive flange, universal joint, slip yoke style shaft, another u-joint, followed by another small stub shaft that would match the spline count of the wheel hub. now with a selectable diff, would it be "open" in the unlocked position? i realize that with u-joints instead of cv joints, the wheels will "jump" when you turn, but is this only true if you lock the front in? just wondering what ppl think of this idea.
2000 Silverado 1500 SB Reg. Cab 4X4
6.0l LQ9 (was 4.3L) w/ stand-alone harness
Electric Fans w/ stand alone B&M trany cooler
Volant Intake
OBX Long Tube Headers w/ Magnaflow 2.5" True Duels
Heavy duty leaf pack in back
4X Rancho RS9000X
Otto-R racing seats
Stainless instrument panel backing
Custom painted red interior
4X 6.5" Light Force lights
31" Wrangler MT/R
Interior roll cage coming soon!
Old 12-13-2006, 03:56 PM
bigbadram51 bigbadram51 is offline
Re: changing out your front diff for another
From what I have read on other forums, some have swaped over to a 3/4 ton front diff, that is big enough you can put a locker in it. Its not easy though, many parts need to be fabbed up. here is a good thread on that http://www.gmfullsize.com/forum/showthread.php?t=64681
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
