Old 12-12-2006, 08:49 PM
Hola Hola is offline
LeSabre - turn signal problem
Our Buick has a turn light problem, which I believe it is a short in the wiring system. How do you find a short and how do you fix it once it is found. Any helps is appreciate it, Thanks
Old 12-12-2006, 11:19 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: LeSabre - turn signal problem
Hola
What type of of problem are you having? The turn signals don't turn on? They blink really fast. They turn on but do not blink? The fuse blows?
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 12-13-2006, 07:47 PM
dvngoodwin dvngoodwin is offline
Hello
does it stay solid and not blink?:if so it is a short my 94 does the same thing on the driver side.alls i do is go in to the trunk and tinker with it entell it works.if you want to do it the right way get a tester.
Old 12-13-2006, 08:22 PM
Thanks, it works on and off. Sometimes stays solid on, no blinks, and sometimes it blinks for a little while and then stops again. I have changed the bulb, and the light soccet, but the problem still persist.
Old 12-13-2006, 08:45 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Have you thought about changing the flasher unit, under the dash?
Some good basic electrical troubleshooting techniques, can be found here.
Old 12-13-2006, 09:58 PM
imidazol97 imidazol97 is offline
AF -Advisor
What year is your leSabre?
Old 12-14-2006, 12:07 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Sounds like a weak flasher if all the bulbs and circuits test out OK.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 12-14-2006, 05:49 PM
Bassasasin Bassasasin is offline
I think there may be a open wire connection.. sometimes the flasher has the load of the lights and sometimes not..
Good Luck
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
