Old 12-12-2006, 11:23 AM
carmine34 carmine34 is offline
93 1/2 ton with Intermit. fuel pump
My 93 1/2 ton 2wd Chevy/GMC 4.3 V6 auto pick up, has some kind of electrical problem. It will start up and drive for 5-30 min. at a time but will eventually stall from the fuel pump (2 years old) not getting power. For some reason the brake lights come on and won't go off at the same time but not always. When I disconnect the battery for 30 seconds and reconnect the brake lights go off and the fuel pump works again until the same thing happens again. Also just recently the brake light on the dash came on but the brakes seem to be fine. Can anyone help? Are the brakes and the fuel pump on the same circuit?
Thanks,
Carmen
Old 12-12-2006, 12:19 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: 93 1/2 ton with Intermit. fuel pump
The fuel pump is on it's own fuse. Sounds like you have a short somewhere.
The brake light you see on the dash is the Anti-lock brake light telling you that you have a problem with the Anti-lock brake system.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
