Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 12-12-2006, 08:08 AM
ssj155trunks ssj155trunks is offline
want to turbo b16a1 in 91 hatch. NEED HELP!!!
im looking to turbo my stock internal b16a1 for around $2500 including fuel and spark . and can i use my vafc 2 to tune air/fuel.?????????can any one help??
Old 12-12-2006, 08:29 AM
Re: want to turbo b16a1 in 91 hatch. NEED HELP!!!
and what kind of management system should i use and where can i find all the stuff i need.cause i want something strong that holds together for an every day driver. if any one can help that would be great?
Old 12-12-2006, 11:08 AM
http://cgi.ebay.com/ebaymotors/Compl...52963363QQrdZ1
this is the turbo kit i was going to get off of ebay is it a good choice? some one let me know cause ive heard bad things about them . but this looks like a good kit to me but im not familiar with turbos.
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
well i would highly recommend NOT using the VAFC. Convert to OBD1 and run something like Crome. You could run OBDO Hondata...which is going to be about the same price.
Other than that, what kind of questions do you have?
by the way, if you buy that kit above, you will be banned from the site permanently...that is a pile of shit that is going to break in no time....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-12-2006, 11:10 AM
how do i convert to obd 1 and where do i find stuff for obd 0 and can i use mega squirt on obd0? thank you for any help.
Old 12-12-2006, 11:12 AM
well what do you think i should do i only have like $2500 to work with. where can i find the pieces to put a good one together?
Schister66's Avatar
AF -Advisor
dont use Megasquirt....there are so many other good programs available for Hondas. I could see using that if you had some other car like a mid 90s Dodge, but there is a wide selection of free programs for Honda. All you would need to do is convert to OBD1 (which means buying a conversion harness and ECU) and then get your car tuned on Crome. You WILL have to get your car professionally tuned if you want it to last....
I made 275whp safely for 5 months before i decided to upgrade my setup...that was on the stock engine too!
Old 12-12-2006, 11:13 AM
Schister66's Avatar
AF -Advisor
www.honda-tech.com has all the info you need
www.hondamarketplace.com has all of the parts you need
Old 12-12-2006, 11:25 AM
so do you think its possible to get i done with that amount of money and what do you think i essentially need to get started with turboing it. im not to great with all of this because i was just looking at the kits and so im tryin to figure it all out.?
Old 12-12-2006, 04:18 PM
Schister66's Avatar
AF -Advisor
yeah you could do it for that amount of money...you need to read up on things first so that you can budget accordingly.
I'll save you some time...search through this thread and you will find all of the answers you need. There are threads on there for everything. One thing that you cant forget to budget for is a clutch, exhaust, and tuning....
http://www.honda-tech.com/zerothread/1024174
Old 12-12-2006, 05:51 PM
i already put a stage 3 clutch in when i had to change the tranny . i put a cable tranny from a 91 acura integra rs? so is that good and its not the best clutch in the world but it grips great?
Old 12-13-2006, 01:34 AM
Schister66's Avatar
AF -Advisor
well then you can count that off the list....you should be able to easily boost it for less than $2500. I bought all new parts and did mine w/ a clutch, tune and exhaust for $2600 approx....
Old 12-13-2006, 06:27 AM
what should i do about exhaust should i go with 3 " with no cat or should i run a catback with a cat?
and what was your set up on you gsr? and do i need to change drive axles i have 99 gsr axles?
sorry for bombarding you but i want to do this right . ? thanx for any help.
Old 12-13-2006, 03:27 PM
Schister66's Avatar
AF -Advisor
i'm running stock axles....i have a 99 GSR....therefore i would say you're fine because they've seen a lot of abuse
yes my setup was on a GSR...i'll list it here in a little while, but as for the exhaust, 3" works well....
