Old 12-12-2006, 07:47 AM
Longknocker Longknocker is offline
Timing Advance wire ...Where is it. 98 s-10 blazer
Can any of you fellas tell me where the Timing Advance Wire is on a 98 S-10
blazer?
It is a 4.3 Liter.
Thanks for the help guys.
Old 12-12-2006, 11:53 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: Timing Advance wire ...Where is it. 98 s-10 blazer
blazer?
It is a 4.3 Liter.
Nowhere. The '98 cannot be timed like the older trucks/engines can.
Old 12-12-2006, 12:39 PM
This vehicle has a distributor cap and a rotor. It is not electronic ignition.
I have looked by the firewall and by the computer but can not find it.
Old 12-12-2006, 01:58 PM
biv343 biv343 is offline
Timing is still controlled by the ECM even though you have a cap/rotor.
Old 12-12-2006, 02:36 PM
OK,
Thanks for the help.I guess there is no way to change timing then?
I appreciate your time, this is a great help.
Old 12-12-2006, 04:02 PM
muddog321 muddog321 is offline
AF -Advisor
The computer is on the pass side under hood - see all the wires by the AC housing. Timing determined by all the sensor inputs and PCM/ECM then adjusts.
Old 12-13-2006, 06:41 PM
wafrederick wafrederick is offline
Banned
The distribitor is set with a scan tool and the spec is 0 degrees.Look for cam sensor retard in the data.You run the vehicle for a second and shut it off.
Old 12-14-2006, 09:09 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
You can turn the dist all day and not change the engine timing.
The dist cam retard setting is for centering the rotor to fire dead on the plug wire terminal.
MT
