Old 12-12-2006, 12:30 AM
jamests10 jamests10 is offline
Exclamation flood damage 2003 taurus
Power Windows Do Not Work, And Are Stuck In Down Position. How Do I Hot Wire The Windows Wiyhout Taking Off Door Panels Or What Do I Check. Help. James
Old 12-12-2006, 06:59 AM
seasonalskier2006's Avatar
seasonalskier2006 seasonalskier2006 is offline
Send a message via AIM to seasonalskier2006
Re: flood damage 2003 taurus
First, hotwiring a window is BAD, that has a huge chance of wrecking the motors. Also, no you cant, but it isnt that hard to pull off the side panels, and if you break some of the tabs holding the door panel on, you can replace em for like 2 bucks, but if you are cheap like me, you dont really need em, the door is just a little shakey.
Old 12-12-2006, 01:03 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Welcome to the forum!
I'm not sure on the 2003 Taurus, but some models will allow you to pop out the power window/lock switch loose from the door without removing the panel. From there you could check for voltage to/from the switch.
How does your thread subject relate to the thread?
-Rod
