Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-11-2006, 09:09 PM
ddaann ddaann is offline
Question Turbo dead
I just removed my turbo so i can still drive my 180 while i hunt down another turbo, can the oil and water lines that went to the turbo be plugged or do they need to flow?
Old 12-11-2006, 10:21 PM
xcusememisswyn's Avatar
xcusememisswyn xcusememisswyn is offline
Send a message via AIM to xcusememisswyn
Re: Turbo dead
im sure they can be plugged, but ur still tuned for turbo and thats noooo goooddd
RB20DET, 260whp, Drive to Destroy.
Old 12-11-2006, 10:42 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Re: Turbo dead
u can drive it, but don't go pass 2500 rpm !!!
hurry with the new turbo!
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 12-21-2006, 12:18 AM
Re: Turbo dead
I welded up a box to replace the turbo so i could get to work and back, i have put a rebuild kit through the turbo and it it feels beautiful compared to the play that was in it before, but i just cant seal the exhaust side 100%, if i fill it with oil and let it sit then it will leak oil slowly i am starting to think even a brand new one would do that. Anyone gotta new T25 lying around that they could fill with oil and see if it leaks out the exhaust side? I figure it would be a similar seal on yo piston rings, and if yo motor was left upside down it would leak past the rings. I want to put it back in the car tonight...so any peer pressure to do so would be appreciated. PS Shaft balancing is for hippies.
Old 12-22-2006, 02:15 AM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
Re: Turbo dead
ive had turbos do that and then sold to people with no complaints so apparently it wasnt an issue. The last T25 i had didnt do that though. Make sure you have the shaft seal installed properly and you should be good.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
