Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-11-2006, 09:01 PM
rock0134 rock0134 is offline
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
1" lower
A friend of mine with a 95 talon tsi awd just bought these shocks and springs off of ebay... they say that they will lower the car 1 inch front and rear. Will he need a camber kit for only an inch of lowering the car or is that only needed when you go around two or so inches. Does anyone here have their lowered an inch?
SOLD
'97 GSX
EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels
'05 blacked out f150 FX4
Old 12-11-2006, 11:21 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 1" lower
If they are cheap springs off ebay THROW THEM IN THE TRASH! If they are good quality then he will be fine. You will be fine in the front, the back is really optional, it will be off a little but it shouldn't be to bad. I would just put some washers behind the upper arm mounts on the rear to push the camber back out a little. Tell him to go ahead and change his struts or his car will ride like shit and he will have to take everything back apart to do change them. And he should go get a full alignment done.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-11-2006, 11:30 PM
Re: 1" lower
I found the link to what hes getting
http://cgi.ebay.com/ebaymotors/TOKIC...spagenameZWD1V
SOLD
'97 GSX
Old 12-11-2006, 11:37 PM
Holset powered 420a
Re: 1" lower
I got the Tokico springs with the Illumina struts. They lowered my car 2 inches
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-12-2006, 12:34 PM
Re: 1" lower
you have a camber kit then right?? will a 1" drop need a camber kit with that set of shocks and springs?
SOLD
'97 GSX
Old 12-12-2006, 06:26 PM
Holset powered 420a
Re: 1" lower
Yes I have one
I would recommend it. They are pretty cheap so he should go ahead and put one on there. With out one his tires might wear out faster
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-14-2006, 06:55 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: 1" lower
Actually you won't need a camber kit. My car has been lowered 2" in the front and 3" in the back for about a month now with -2 degrees camber in the front and -3 degrees camber in the back and my tires haven't seemed to wear at all. As long as you get an alignment you should be fine as far as tire wear is concerned. Because its not so much the camber that eats tires but its really the toe out that eats tires. The negetive camber is actually where alot of your handling comes from. I say just lower it and get it aligned and you should be good to go.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 12-14-2006, 07:55 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: 1" lower
Camber WILL wear the tires quite a bit. Toe will aslo wear the tires but in a completly different wear pattern. I would reccomend a camber kit and an alignment with any suspension alteration, that and I'm an alignment tech haha
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 12-14-2006, 08:10 PM
Re: 1" lower
My alignment guy told me that camber can wear out tires over a long period of time. But he says as long as your toe is straight then you can run -camber without ruining your tires, and so far that has proved true in my case.
Caleb
vanilla gorilla
Old 12-14-2006, 09:14 PM
showstopperz's Avatar
showstopperz showstopperz is offline
Re: 1" lower
The master certified mitsubishi tech at the dealership that I work at has a set of tien(sp?) springs and a set of shocks that will lower my car 2 inches and he promises me that I would not need a camber kit? Is he correct? I dont usually question his knowledge but seeing this thread is making me think about it.
He said he would sell me the springs and shocks for $350.00. That includes instalation and a full allignment. Is that a good deal? Should i buy them?
1998 spyder gst 5 speed
2007 Mazda SPEED3
Old 12-14-2006, 09:54 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: 1" lower
Sounds like a deal. I would assume he knows what he is talking about, but if he does the work at the dealership than it's warrantied and that makes it worth it.
If he messes up and the tires do wear because of the camber you could probably take the car back to him and tell him to fix it.
1991 GSX 2.3 Stroker
Old 12-14-2006, 10:11 PM
blk_srt's Avatar
Re: 1" lower
camber(as long as its equal on both sides)wont cause any driveline issues nor will it cause the car to pull but it will wear the tires, it wont wear as fast as a toe problem but it will wear prematurly
Mods:
Old 12-14-2006, 10:19 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 1" lower
I burnt up the insides of a brand new set of tires over 1 summer because of camber, I'd suggest getting a camber kit. They're cheap ass insurance, why wouldn't you get one?
95 Talon TSI AWD
97 Eclipse GST
Old 12-15-2006, 12:19 AM
Holset powered 420a
Re: 1" lower
Also to much camber will hurt your cars handling.
98 Eclipse GS Turbo
2001 BMW 325i - DD
