| Engine intakes, exhaust, turbos, nitrous. |
Anyone used a Unorthodox underdrive pulley on their SR20DET? Are they are the same pulley used on the SR20DE? Also, who has the best price on them? That is if it works for the DET.
TIA, G20er |
Re: Unorthodox Pulleys
George Roffe Houston, Texas USA 00 328i 91 SE-R (well modded) 84 944 SCCA ITS race car under construction "I fear all we have done is to awaken a sleeping giant and filled him with a great resolve" -- Admiral Yamamoto, December 7, 1941 |
Re: Re: Unorthodox Pulleys
I appreciate the info. Now, how much do they run in terms of pricing?L8r, G20er |
The list price for the two pulley set is $259
Owner of Primeraweb, and a 1997 Nissan Primera SRi driver |
Here is a question though - if you just get the two pulley set, do you need a different sized belt? I've read conflicting reports, some saying you do, and some saying that you only need a different belt for the four pulley set.
Can anyone confirm either way?
IMHO pulleys are a wonderful mod. The only downside is reduced AC at idle. Big deal. In fact, anyone doing lapping should definitely run them since they slow down the waterpump. This is very important since the waterpump cavitates at high rpm. So underdriving the waterpump actually improves the cooling at high rpm. ![]() What's really great is it adds power and throttle response without adding noise or other nasty things. ![]()
Thats why I'm getting a set!
![]() I just wanted to know whether or not the two pulley set needed a different belt or not. Logic told me that it did, but a couple of sites said that it didn't so I needed to check before hand. I'm ordering the pulleys from America when I live over here in the UK, so I need to make sure I get it all right first time.
The part numbers that UR lists are:
Alternator and A/C - 91- 98 Gates K060390 Water Pump and P/S (Ultra S) 91- 91 Gates K040340 IIRC those are a 6 rib 39" belt and a 4 rib 34" belt. Correct? BTW, I picked up my pullies for about $160 at a local shop in Phoenix, but i know most places sell them for around $175-200.
Justin McClanahan 95 G20 15.4 @ 91.4mph (2.4 60ft )143.7whp and 131.4 ft.lbs Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff... |
how much more horsepower and torque do you gain and is it hard to install it? Instructions would be cool.
It took me just under an hour to intall the 2 pulley set on my SR20DE that was in my P10 before I installed the DET.
and when you do it you should replace your crank seal since it is probably seeping a bit. mine was when i put my pulleys on.
gone through so many cars i can't keep track. all i know is i have a gsr swap on the floor of the garage that is going in a teal boxy hatch. |
Anytime you break a seal you should replace that gasket or seal.
It may not be a bad idea to replace the seal even if it isn't leaking, especially on a high mileage car. I don't think it was over $4.00, but I may be wrong on that, it's been a while since i installed my pullies. Oh yeah, if your motor is in the car it should take about an hour or two for the install, if it's on a stand for any reason the install should take all of about 5 minutes.
OH yeah, I'm an idiot... the other thing i really wanted to mention was that I had some trouble getting the PS pulley on the PS pump due to the inner diameter of the hole in the pulley being smaller than the outer diameter of the aligning bump on the pump itself (if that makes sense). You'll know what i'm talking about as soon as you see the UR pulley and the stock one. For me, the hole wasn't quite big enough, and no matter what i did the pulley wouldn't sit flush. I just took a round file, and very very carefully filed the hole a tad larger, making sure to do it very evenly as to not make the pulley out of balance. It didn't take much, I'd say maybe .5mm. The sizes were barely off, but i had to do this in order for the pulley to fit properly.
rather than a round file i used emery paper...it works a bit slower which on aluminum is better. take it until the anodizing is just worn off a bit. that should be enough. ur has all of the measurements correct before they coat it, when they get coated it sets them off a bit.
