Old 12-11-2006, 06:17 PM
Brandon McGregor Brandon McGregor is offline
slow shifting
I have a 96 jeep cherokee sport 4.0 litre HO automatic and it has a 3.5 inch lift on it and i am now finally getting into fixing a few things on it and first up is the slow shifting that it has. If i put it into 3 then it does alright till i get to higher speeds. In drive it is slow shifting from 2 to 3 and it boggs down quite a bit. I am wondering about anyones thoughts on this.
Old 12-12-2006, 01:18 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: slow shifting
Change the fluid. Do a flush if you can ...it will cost you about 12-13 quarts of fluid.
Make sure you use Dexron III/Mercon fluid..not synthetic.
To go further...take the pan off and change or clean the fliter/screen.
Old 12-12-2006, 07:09 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: slow shifting
Do you have larger tires on it? If you left the gear ratios stock then that's likely the reason it's bogging.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-12-2006, 11:54 AM
AlohaBra's Avatar
Re: slow shifting
Hey..Fred might be right...I didn't read your post carefully.
Most people that use 32s and 33s on their rigs drive around in 3rd gear if they didn't re-gear the axles.
