Old 12-11-2006, 06:08 PM
musickys88 musickys88 is offline
6G72 mitsubish galant 3.0 engine into a 3000gt?
i have a 1999 mitubishi galant with a 3.0 liter v6 and the engine type is a 6G72. i have noticed that the 1991-1999 mitsubishi 3000gt's also had a 3.0 liter v6 and the engine type is a 6G72 also . now can i swap my engine from the galant into a 3000gt/dodge stealth and if so what mods will i need?
Old 12-11-2006, 07:05 PM
AutostradaVR4 AutostradaVR4 is offline
Re: 6G72 mitsubish galant 3.0 engine into a 3000gt?
im fairly certian that the tranny is on the opposite side in a galant. if your going through all that trouble, you might as well drop in a 3.5L 6g74. Same work involved. Why? you looking to but a 3/s with a blown motor?
EDIT: Actually, i was thinking of the 4cyl galants, the V6 is on the drivers side (i think...) so it should go in all good. may wanna check if the tranny mountup is the same though.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 12-11-2006, 10:40 PM
Igovert500's Avatar
blue + red light magnet
Yes, anything is possible. But if you are asking this question, (and no offense) but hte answer you need to hear is NO. It isn't a direct swap. The tranny is mounted opposite, AFAIK, as mentioned above. So you would need to swap in teh accompanying tranny, then do a hell of alot of customization/fabrication.
Bottom line, just because 2 cars have teh same block code doesn't mean they have hte same engine. Hyundia Sonatas had a 6g72...same situation.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-11-2006, 10:50 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Originally Posted by Linebckr49
do you happen to also have a 3000GT that needs a new engine? if not, then there's no point in swapping.
like i said earlier, and what Igo and everyone else said.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-11-2006, 11:33 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Too correct Igo. Hell even the SOHC and DOHC 6g72 in the 3s's arent the same. oil pump, accessorys, everything is difference on them.
Old 12-12-2006, 08:43 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Also the galant SOHC are 24 valve, where our SOHC are 12 valve.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 12-12-2006, 01:34 PM
wait so now im a lil confused as to what i can and cant do. right now i have a 1999 mitsubishi galant with the 24 valve v6 6G72 motor and transmission and all other parts on car. what do i need to do to make my engine compatable in a 3000gt
Old 12-12-2006, 01:47 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
I'll make it clear, you can't do it.
Now the only reason anyone mentioned the possibility of it happening is because anything is possible, you could build your own ferrari if you wanted and had the skills, but doing this would take just as much fabrication.
The two engines are mounted in opposite directions.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 12-12-2006, 01:48 PM
Linebckr49's Avatar
93 3000GT base
Old 12-12-2006, 01:52 PM
2old 2old is offline
Put another way... The engine is not "compatible", the engine block is.
The question is why you are trying to put the galant engine in the 3000gt? If you are thinking it's a simple replacement, it's not worth doing... If you are tearing the engine down and re-building it in the 3000gt then maybe.
Old 12-12-2006, 02:59 PM
Step 1, Put Galant engine on ebay.
Step 2, Buy 3000GT engine from ebay.
Step 3, there is no step three, its that simple to convert your engine.
