Old 12-11-2006, 05:17 PM
monkeyspanker55 monkeyspanker55 is offline
water pump squeel stalls
i have located a squeal in the waterpump area when the squeal starts engine dies?
used a hose to locate squeal area its in the water pump area?
then car stalls out like there is a drag on the belt???
anyhelp would be appreciated?
heard vacuum leaks to camshaft sensor??
plz help
Old 12-11-2006, 10:03 PM
wiswind wiswind is offline
Re: water pump squeel stalls
Your profile says you have a 2000 windstar, which I am not familiar with...as I have a '96.
The made major changes in '99.
I would find it hard to believe that your water pump would cause enough of a drag to load down the engine.
You could try loosening the serpentine belt and turning the water pump pulley by hand....and see if it is hard to turn.
I would give the idler pulley are real hard checking out.
On my '96, it is right next to the water pump......etc.
They are known to fail.
Also, check to see if the tensioner is holding the serpentine belt tight.....and also check to see that there is not any oil / coolant, etc on the belt and pulleys that could be causing it to slip.
The windstar is also known for cooking the power steering fluid.....and the worn out fluid will make the power steering noisy.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 12-12-2006, 06:31 PM
Well definatly sounds like a water pump bearing?
had it all apart and no squeel leading me to believe water pump since it doesnt turn>???
anyone have suggestions?
