| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
HELP! ASAP! Potential FIRE!!
Hello. I just got my system installed today. While driving (and listening to the stero with base) I smelled a burning smell. I stoped the car, popped the trunk and the smell was really strong there (where my box and amp is). Am i frying my amp or is it something else? I have a pyramid 1600 watt amp pusing two 600 watt 10 inch subs. I am using my factory head unit with a line out put converter in the trunk spliced into my rear speakers. Is the line output converter hooked up wrong? Maybe the positive and negative is mis matched. Please help before a fire starts somewhere. Thanks
Re: HELP! ASAP! Potential FIRE!!
By the way I have a 98 chevy malibu. he hooked the negative wire on the loc to the brown rear speaker wire, positive to yellow, negative to dark blue, positive to light blue. Is this correct?
I just turned my car on and was checking for smoke and here the amp was smoking. Now it wont turn on so its fried...... I think I found out why. I have (had) a two channel bridgeable amp, pushing to subs, and here the guy who installed it had it set not on stero but on bridge..... Any one else think thats why it fried?
Wrong impendance possibly, but the fuses should have blown in either the power wire or the amp first. But pyramid is cheap low quality stuff and i done even know what subs you have.
Cant remember who posted it but if you see it give yourself credit Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota. Cardomain |
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
Sorry I am new to all this. Whats independance? ANd yes it blew my amps fuses. Thanks
2001 Ford ZX-2 Alpine CDA-9855 SAX 100.4 Rainbow CMX 265 front stage Stock 5X7 rear fill Hifonics BX1505D TC-5200 |
impedience is the resistnece.
Impedance is the AC resistance of the speaker. The lower the number, the harder the amp works.
i thought it was DC resistance
the voice coil in the speaker does have a DC resistance ...... it's a long, thin wire, but music is NOT DC. Resistance in AC is called impedance because there is an inductive and capacitive reactance as well. The only work done by a speaker (moving air) is accomplished thru the reactance - and since a coil of wire is mostly inductive, the inductive reactance.
Thanks for all the replies, but this is all spanish to me..... SO no one thinks that how it was set on bridged instead of stereo when I had two subs hooked up on a two channel amp fried it? Should I buy another amp, or will that one fry also?
I'm saying the amp probably blew because it's a Pyramid which is quite possibly the worst brand there is in this hobby, but before you hook up any other amp you need to check what impedance the speakers are wired to because whoever installed it may have wired them to some ridiculously low impedance that would blow any amp that tried to power them.
