Old 12-11-2006, 02:33 PM
Mtxracer Mtxracer is offline
Need Help No O.D.
This my first post on here as I am a newby. What I would like to know is what makes the transmission shift into OD. I have tried adjusting the switch on top of the trans and that makes no diff.This thing run's about2600-2800 rpm to run 50 mph and uses gas like a pig. My wife drove it all the time and I just sold my p-up and got her a new Escape, now I have to drive the Taurus wagon to and from work. It's about 20 miles one way and I am using a 1/4 tank of gas a day to go to work and back. Heck my 5.4 F-150 wasn't that bad!!! Thank's in advance
Tim
Old 12-11-2006, 06:02 PM
TaurusKing TaurusKing is offline
Re: Need Help No O.D.
What year?? No od could be a myriad of issues,, any trans codes read???, or check engine light ever been on???
Old 12-11-2006, 10:21 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Welcome to the forum!
I assume you are referring to your 1997 Taurus. Do you know which transmission your car has (either AX4S or AX4N)? Also, which engine does your Taurus have (12V Vulcan or 24V Duratech)? Is the "OD OFF" indicator in the instrument cluster on or off?
-Rod
Old 12-12-2006, 06:58 AM
Rod
Yes I am referring to the 97-Taurus and I beleive it has an AX4N trans, it is the Vulcan engine, and there is no "OD OFF" indicator in the dash, never was and I have owned this thing since new. I had the trans scanned last nite and it show's a "C" clip error on the spool in the valve body. Can this be fixed without removing the trans? Thank's Tim
Old 12-12-2006, 01:07 PM
shorod's Avatar
SHO No Mo
I had a 1993 Taurus SHO ATX that didn't go into overdrive. There was an e-clip on the OD solenoid that broke and prevented the tranny from shifting into overdrive. If the layout of the transmission in your 1997 has not changed much since my old 1993, it can be replaced without removing the transmission. You'll need about $0.17 for a new e-clip.
I found the procedure on the SHOtimes forum, and it was documented pretty well. Took me a couple of hours which included the time to take photos and take the remnants of the broken clip to the hardware store to match up a replacement.
-Rod
Old 12-13-2006, 12:25 PM
-Rod
Rod thank you. Where is the SHOtimes forum at? I tried a search and didn't see anything maybe I didn't look in the right spot or could you give me a link. Thank's Tim
Old 12-13-2006, 05:59 PM
shorod's Avatar
SHO No Mo
http://www.shotimes.com/php-bin/modu...hold=0&sid=102
-Rod
Old 12-13-2006, 06:48 PM
Thank's Rod, I appriciate that.
Tim
Old 12-13-2006, 09:46 PM
shorod's Avatar
SHO No Mo
You're welcome. If you are curious what it looks like, I have some low resolution photos of what it looked like and where it was located on my 1993 SHO.
-Rod
Old 12-14-2006, 09:32 AM
-Rod
Please post or send them to me, Thank you. Let you know how I make out. Tim
Old 12-14-2006, 12:49 PM
shorod's Avatar
SHO No Mo
Send me a private message with an e-mail address for you that can accept JPG attachments. They were taken years ago on my 0.9 MPixel camera, so they are small files.
-Rod
