Old 12-11-2006, 11:06 AM
derekbitt derekbitt is offline
rear diff leak
I have 98 z71 that i changed the rear diff lube in. since then it has a very slow leak that i cannot fix, although i have tried to redo it 3 times but it still leaks. i have tried using rtv, cork gaskets and both, with the same result. has any one solved this problem? what did you do?
Thanks in advance
Old 12-11-2006, 07:32 PM
butch h butch h is offline
Re: rear diff leak
Is it possible that you have a blocked/plugged vent?
Old 12-11-2006, 08:28 PM
Re: rear diff leak
i can tell its leaking from between the cover and the case.
Old 12-11-2006, 08:36 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: rear diff leak
That can be deceptive - a leak at the vent can cause the oil to wick down the gasket, leading you to believe that it might be a gasket leak.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-11-2006, 08:40 PM
Re: rear diff leak
thanks, ill take anothes look at the vent line tomorrow
Old 12-15-2006, 10:35 AM
MyTOY's Avatar
MyTOY MyTOY is offline
Re: rear diff leak
I also need to look into my leak. I haven't looked for a vent & might find it if I look but where is it & can I service it myself if leaking? I wanted to put synthetic in it then I saw a tech bulletin saying not to use synthetic if RTV was used as seal & there is a kit to replace RTV with gasket but there is more to the kit than just the cover gasket & i'm not sure if I can handle the other part of the gasket replacement. I forget exactly what the other gasket(s) were for. Any advice is appreciated. Thanks
03 WRX
Old 12-15-2006, 02:26 PM
Re: rear diff leak
The vent isn't necessarily leaking,BUT,if it is plugged,it can cause any and all seals/gaskets to leak.
Old 12-16-2006, 07:21 AM
69Charger 69Charger is offline
Send a message via MSN to 69Charger
Re: rear diff leak
Are you cleaning the gasket surfaces enough and soaking them in brake clean to get the messy oil off of it? RTV can't seal to oil... Try using stuff called "Right Stuff" Its fantastic for doing that kind of work.. I'll never crack another diff without a tube beside me
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
87 Mustang GT, 5.0L 5 spd, MSD ignition, BBK tubes, flowmasters, tri-ax shifter, 4.10 gears
69 Charger SE, stroked & poked 383,727 over 550rwhp
86 Chevy 2500 4x4 Plow truck, 350/TH400, 8ft fisher plow
