Old 12-11-2006, 08:02 AM
tegger tegger is offline
Send a message via Yahoo to tegger
Loose Steering
After chaniging a 'strut bearing' on the passager side. My car feels like the 'steering is loose' when driving down the highway at 60+ mph, You have to really use both hands to keep it from 'drifting'. Anybody have any ideas? Alignment? Thanks
Old 12-11-2006, 09:51 AM
bedpan bedpan is offline
Re: Loose Steering
Any time you do any kind of front end work, you need to have it re-aligned. Always get a four-wheel alignment, not just the front end, to make sure the car is straight as an arrow. The shop will probably push a four-wheel anyway to get the extra bucks but it should still be only about 75 or 80 bucks.
Old 12-12-2006, 09:48 PM
Bassasasin Bassasasin is offline
Re: Loose Steering
Just to note a slight Toe in tightenes that slop you feel. Too much toe in will cause it to "take off", or want to turn too much too fast, besides wearing the tires.
An allignment is most often in your favor when your needing front end attention. Good technicians have the skills to check for looseness in other parts.. Its this technical knowledge and those trained hands, eyes and equipment that you pay for.
Dont forget tires too!
Good Luck
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
Old 12-13-2006, 09:18 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: Loose Steering
Yup, as already been said you need an alignment. Might as well check out your other front end parts (namely tie rods and ball joints) for slop as they will require an alignment if they're bad.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
