Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-11-2006, 09:01 AM
OD53 OD53 is offline
Check Engine light from cold coolant
2000 Grand Marquis with low (50,000) miles. When driving at high speeds (65-75) for extended periods (30 min +) coolant drops out of target range, no more heat and eventually check engine light comes on solid. Mechanic said I should warm it up better, but even if temp is mid-range prior to highway driving situation still occurs. Baffling in 20 degree weather than car engine can't drive extended at 70 mph.
Old 12-11-2006, 10:32 AM
sheebeehuh sheebeehuh is offline
Re: Check Engine light from cold coolant
You most likely have a bad thermostat that is sticking open. Driving at highway speeds in 20 deg weather with an open thermostat (or if the thermostat has beem removed) will cause the symptoms you describe.
You probably need to change mechanics as well.
Old 12-11-2006, 11:02 AM
I wouldn't be surprised if both were true, thanks.
Old 12-14-2006, 11:18 PM
KimMG KimMG is offline
AF - Advisor
Did you also check the coolant level? If the thermostat is not sticking open, try partially blocking the radiator, the way truck drivers do, to prevent the radiator from overcooling. Also have the codes read to make sure there isn't an underlying problem. Autozone will do this for free.
