I have a 2004 SEL and occasionally the gas pedal will vibrate. It usually just does this when the car is cold but sometimes it'll vibrate when it's warm. Any idea what could cause this?
Re: Gas pedal vibrates.
That's almost got to be due to a vibration in the engine. Is your 2004 throttle-by-wire? If so, there is no physical connection of the accelerator pedal to the engine, just the body of the car.
-Rod |
I had the same problem on my '01 duratec. Turned out to be the throttle cable was rubbing against part of the airbox. The cable is sheathed in thick foam where it runs to the engine under the hood. My cable had rubbed through the foam by vibrating against something under the hood. I stuffed a piece of foam in and wire tied it around the existing cable. Then used some ties to hold the cable apart from touching anything, and added some more foam where I thought it might also rub. The vibration has all but dissapeared. To think, I went a year enduring that before I decided to have a look. Simple fix, good luck!
It seems to be a common problem ... mine does it too. But I don't really see anything wrong with it.
And I believe they are all gas pedal connected to throttle.
![]() - Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers - As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee! |
Ford has a TSB on this. It is TSB number 04-26-15. It addresses the need to install a new cable bracket to keep vibration from coming through the accelerator pedal.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
i have the same problem on my 1999 ford taurus se sport 24valve duratec
