Old 12-10-2006, 04:33 PM
epecenter epecenter is offline
EVAP system Malfuntion 98 blazer
i have a 98 chevy blazer 4 doors with normal problem but i being able to fix most of them, not all of them.
i have check the whole system for leaks and can't find any i also replace the evap charcoal canister and i still get check engine code p0440. gas odor are near the gas door on the outside and inside too but i can't find any leaks.
Old 12-10-2006, 05:02 PM
Blue Bowtie's Avatar
Registered Offender
Re: EVAP system Melfuntion 98 blazer
Welcome Aboard!
Have you tried a different cap yet? The 'O' ring or the vent valve could be damaged.
Old 12-11-2006, 09:38 AM
Originally Posted by Blue Bowtie
Welcome Aboard!
this is my third gas cap i got the first two from autozone and pepboys and the last one i got it from the dealear.
how could i check the O ring and the vent valve.
Old 12-29-2006, 12:19 PM
boomer62 boomer62 is offline
Re: EVAP system Malfuntion 98 blazer
I had this code on my 99 blazer 4x4 4 door. There is a module at the back of the gas tank, ( back of gas tank and front of spare tire on my blazer). If i remember right there are two hoses and one electricial plug to it. Replaced it (35.00) Problem gone. Hope this helps.
Old 12-29-2006, 01:22 PM
DINO55's Avatar
DINO55 DINO55 is offline
Boomer,
Thank You for Posting your truck's P0440 FIX............
I think it's called a purge solenoid. We replaced one on a family members 97 Blazer last year and his P0446 code has not returned, I think he got one for $12.00 on the internet....
(Thanks again for your help last year MT2500)
Dino...
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 01-12-2007, 11:17 AM
Smile Re: EVAP system Malfuntion 98 blazer
I finaly got the EVAP problem fix, once I drop the gas tank i found a disconected fuel hose. The hose wasn't clamp two years ago when a shop replace my fuel pump and with time it disconected it self. i also replace the O ring on the fuel pump.
