Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 08-31-2001, 04:27 PM
zykotik zykotik is offline
Send a message via ICQ to zykotik Send a message via AIM to zykotik Send a message via Yahoo to zykotik
Swapping to DET
Ok I know I said I was gonna paint but my engine gave me a horrible surprise today. I just want to know what is needed for the swap (other than the engine ) and if I can get away with using my NX tranny.
Any help would be appreciated.
-Objects in mirror are losing-
www.npclub.com
Old 08-31-2001, 05:48 PM
P10DET's Avatar
P10DET P10DET is offline
Re: Swapping to DET
You can use your NX gearbox. You won't really need much beyond the engine. You will have to fabricate a downpipe. If you want a FMIC, you will have to fabricate piping. You should install new rod bearings and main seals. You'll probably want a new clutch too.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 08-31-2001, 08:40 PM
Thnks Geo!
You the man...Now I don't know much about turbo (amateur gearhead) so it'd be cool if you could explain why I need piping and what is a Fmic (sp?) Also I installed a brnd new clutch with my swap to manual 2 months ago should I really change it again?
www.npclub.com
Old 08-31-2001, 08:54 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
Thnks Geo!
Piping is needed because on a turbo engine, the downpipe leads to your cat. FMIC = front mount intercooler, you will need to make piping for that leading to the turbo, i think so, sorry im not that great with turbos either. dont know much about the clutch, but id think it would work using the same tranny.
1.6 - The Underdog
GA16DE-T Club!
Old 08-31-2001, 09:17 PM
P10DET's Avatar
I think the DET will over power a stock clutch. The DET delivers 50% more torque than a stock DE.
George Roffe
Houston, Texas USA
00 328i
Old 08-31-2001, 09:46 PM
So I will need a clutch specific to the DET then?
Have a part# ?
Also I think I will need some sort of guages? and ECU?
Did you do this swap yet geo?
Sorry to bombard you with questions I just want to be sure of what I'm gettin myself into. Want to make sure I have ALL the parts I need before ripping the DE out.
www.npclub.com
Old 08-31-2001, 11:08 PM
P10DET's Avatar
You won't need a clutch specific to the DET, but you will need something more powerful than stock. I'm using a JWT clutch. It has 40% more clamping force, yet the effort is lighter than stock. Honest. It's a great clutch.
Have a part# ?
No, but JWT sells a bunch of them. Just tell them you need their SR20 clutch.
I'm not running any gauges, but most people do. Most popular are boost, oil pressure, oil temp, water temp.
For ECU there is only one choice to consider: JWT. Totally plug and play. No worries.
Yep. Been running for over a month. No problems. I did go with a double row radiator though. It would start to over heat in stop and go traffic in 95F + temps.
If you want to do the FMIC, Hotshot will be making a kit. I'm going to make another set of pipes and send them to John so he can make a kit from them. The IC they supply fits really well behind the lower grill and the piping is pretty slick if I do say so myself.
George Roffe
Houston, Texas USA
00 328i
Old 09-01-2001, 11:56 AM
Ok so If I've understood correctly I must change my ECU or reprogram it?
Yep good plan for the clutch gonna order that from JWT.
As for the double row radiator, I was thinking about trying to get a Diesel radiator I read somewhere that those were really efficient (sp?) We have lots of traffic here but winters comin so no 95F for me...what does that work out to in Celsius?
So for now it is clear that I need:
Engine
JWT Clutch
Guages (personal choice) I would'ne mind them on the drivers side windshield beam
www.npclub.com
Old 09-01-2001, 12:32 PM
P10DET's Avatar
Yes, absolutely.
The ACT is also a good clutch, but it requires a higher effort. I've got two JWT clutches and I really like them.
The Diesel radiator is a good idea. I was looking into that initially before I found the double row. I only paid $155 US for it, so it may still be cheaper than the Diesel radiator. It is aluminum core with plastic tanks. The only thing I don't like about it is the inlet and outlet are smaller diameters with rubber adapters. They are kind of cheesy, but the radiator is great.
About 35 or 36 I think.
Engine
JWT Clutch
And the ECU. Once the Hotshot kit is available, it will make the swap pretty doggone easy.
George Roffe
Houston, Texas USA
00 328i
Old 09-02-2001, 12:09 AM
Cool, I think I'm on my way to DET then. There is an NX2000 here with a DET in it but the ego maniac that owns it refuses to tell me anything about how its was done...He owns a garage and expects I'll let him do it.
NOONE works on my car except me
www.npclub.com
Old 09-02-2001, 12:25 AM
P10DET's Avatar
Good for you!
It's a pretty straight-forward swap. The Hotshot kit will make it a no brainer. A complete how-to write-up with photos is about 1-2 months away.
George Roffe
Houston, Texas USA
00 328i
Old 09-02-2001, 09:58 AM
I wish I could wait for the write up but my engine is knocking from cold now...even with the infiniti oil filter...BTW The Hotshot is not imperative is it? Could be a stupid question but I want to get all the questions out of the way.
www.npclub.com
Old 09-02-2001, 12:07 PM
P10DET's Avatar
No, it's not imperative. I installed mine w/o one.
Basically, you will have to fabricate a downpipe at the very least.
For intercooling, you are faced with a moment of choice. You can either run the stock top mounted intercooler or you will have to find a front mounted intercooler and have the piping fabricated.
I'm hoping to get pipes to John within a month.
George Roffe
Houston, Texas USA
00 328i
Old 09-02-2001, 09:01 PM
Ok I'm gonna run stock intercooler for now, get that fancy rad and do a JWT clutch. ECU will be reprogrammed but what can't I just use the ECU that comes with the engine I'll be buying?
They sell em WITH the ECU here.
www.npclub.com
Old 09-02-2001, 10:00 PM
P10DET's Avatar
Well, here is the problem. Some people have said you can. Some people have said no. I've heard the MAF for the BB is different from the North American market cars and I've heard it's the same.
The real problem is I've yet to find anyone document that you can. I've yet to find anyone to say "I'm running a stock Bluebird ECU and here's how you do it." I cannot say you can or that you cannot. If you can get the engine wiring harness with the engine (uncut), along with the ECU and the MAF, you will probably be OK. You might have to figure a few things out.
If you go this route, I implore you do document what you did. Some folks think I'm just a JWT lackey, but the fact is, they create a plug and play solution. All other solutions I've heard are undocumented. So, if you figure it out, please document it so others can learn from your experience. I'm not trying to be a smartass. I'm quite sincere.
George Roffe
Houston, Texas USA
00 328i
