Re: 1990 Dodge Dynasty transmission postioning sensor
First of all, the term "turn over" is very ambiguous. Some people use this term instead of saying "the starter doesn't operate". Others use this term instead of saying "the starter cranks but the engine won't start and run on its own". So you need to be more specific about what is happening with your car.
Assuming that your starter is not cranking (turn the key and nothing happens), you could have a bad nuetral safety switch. If this is the case, try starting the car in both Park and Neutral. Then I suggest holding the key in the start position with one hand and moving the shift lever through each gear to see if the starter will engage at some point. If none of this works, disconnect the switch and put a jumper wire between the terminals. If the car starts now, then the switch is bad. You could continue to run the car with the switch jumpered, but you run the risk of starting the car in gear, not a good thing.
Now, go at it and let us know what you find.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
