Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 12-10-2006, 12:01 PM
johnd4ever johnd4ever is offline
89 Econoline Van Won't Start
I've replaced the battery, the starter and the starter relay. Will not start when I turn the key over. It does click, but that's it. I can start it by bypassing the starter relay.. I'm stumped.
Also, does anyone have or know where I can find online the fuse box diagram?
Thanks
Old 12-28-2006, 09:15 PM
mustangmike351c mustangmike351c is offline
Re: 89 Econoline Van Won't Start
check ignition switch under steering column. the small wire going to the relay should have battery voltage when you turn the key to start and 0 volts in all other positions
