Old 12-09-2006, 09:54 PM
JCWindstar JCWindstar is offline
Can IAC fault cause emission warning light
on a 2001 Windstar, would a faulty IAC valve cause the emissions warning light to come on?
I have been having trouble with the idle when the temperature is below 30 F so was instruct to clean the IAC valve. Did so, then the emmision warning light (the little yellow engine icon) came on about 2 miles later.
Would this be caused by the IAC? (I currently do not have a rader for the codes so am working "blind").
Old 12-10-2006, 03:04 PM
busboy4 busboy4 is offline
Re: Can IAC fault cause emission warning light
Hi
yes there are fault code associated with the IAC. However, there are many, many codes that will trip the "check engine" light. Try and have the code read at an Autozone or similar store. They will do so for free. Then post back what you learn.
Old 12-10-2006, 10:56 PM
catvents catvents is offline
I have got exactly the same thing just a week ago, after having cleaned the
IAC because of rough idle after starting. The cleaning has fixed the problem
but the the light goes on a little while after. I do not have a OBDII scanner
to check the code (maybe for chrismas but I have disconnect the battery ( not recommanded I know) to erease the code and turn off the light. So far, after about 250 miles the warning light did not glow so I think it was related o the IAC. Will see if it remain off.
Old 12-11-2006, 07:38 PM
The fault was from the IAC valve. Replaced it today and reset the engine light. All seems to be working.
THANK YOU for the posts -- very helpful!
