Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 12-09-2006, 08:22 PM
WhosYoDaddyKoo00 WhosYoDaddyKoo00 is offline
Straight Pipe in Place of Cat?
Hey, I was wondering if I replaced my cat convertor with a straight pipe would it effect my ECU? I know that the o2 sensor is before it, but is there still a chance that it would be effected by the loss of backpressure, or in any other way? If its a legit mod without screwing up with ECU, what would be the diameter of the straight pipe? And how long?
My GM city has turned ricy.
Old 12-09-2006, 09:48 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: Straight Pipe in Place of Cat?
use the same dia. as your cat. and get a ''test pipe'' they have a place where you can screw in your O2. it wont do much, although i heard you do have to change some stuff on the ecm? someone with more knowledge?
and.. make sure its a.ok for your smog.
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 12-09-2006, 10:10 PM
goldz28's Avatar
goldz28 goldz28 is offline
Do you have emissions? If you take the cat or cats off you will need to have someone tune out the rear o2's or you will get a code and your check engine soon light will come on. The rear o2s have nothing to do with how the car runs just makes sure the cats are doing their job. I read that getting rid of your cat takes 3% or so of the back pressure so you get alil better flow.
Hope that helps
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 12-09-2006, 10:21 PM
No offense, I'm not trying to disregard your advice, but I wanted to know from someone who may have done it already. And we dont have emissions tests in Michigan.
Old 12-09-2006, 11:08 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
You don't always get a gain with it. Some people have actully lost hp when they have did this.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 12-10-2006, 06:42 AM
goldz28's Avatar
Non taken, I don't have any cats on my car. The ECU is not effected in the way the car runs but you will get a check engine light due to the fact the car thinks the cats are not working properly or the o2 sensors are not working. There are no emissions in Oregon either.
I noticed the car ran better and the sound was louder.
What size of engine do you have?
Old 12-10-2006, 01:00 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
A benifit you will notice if if you remove the cat and then tune it, you can delete the COT protection (cat over temp, dumps in extra fuel at WOT since going lean kills the cats), allowing you to tune it a tad bit more lean and therefore increase the power, and also saving fuel (although at WOT who cares about gas mileage lol), and reducing the overwhelming cas smell of a catless car
What I'd do is this: get a bullet muffler instead of a straight pipe... that way it'll quiet it down some.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 12-14-2006, 10:55 PM
Well, I just figured I wouldn't get a check engine light 'cause the o2 sensor is before the cat. I'm guessing that it is possible for it to notice if one was gone because of pressure, but I dont know. Well, my engine is a 3.8litre, 3800 engine to answer Goldz question.
Old 12-15-2006, 12:48 AM
there's an o2 after the cat and the only thing it does is make sure the cat is working fine. Tune that out via hptuners, texas speed, PCMFORLESS, etc and no problems
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 12-18-2006, 12:49 AM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
I've cut the cat out of my 3.4, haven't got any lights (knock on wood), and it's been out for over 6 months now! Sounds deeper, but with the lost backpressure, the muffler will 'pop' or rattle if you accelerate up/around 3000-3500RPMs before it shifts, only reason I cut mine is because it had fallen apart in the casing, and made the car sound like a rolling can when idling.
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
