Old 12-09-2006, 08:00 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Question about Clutches
Tell me if I should go to the Tracker Forum or can I ask it here?
I am so used to this particular forum and you folks I know.
My wife's '93 Tracker's clutch has a "Click" to it. Didn't used to....
The pedal pushes hard and then when almost all the way in, sort of
releases like a "click" and becomes easier.
Would this likely be the clutch mechanism inside the Transmission or would
it be something worn on the foot pedal mechanism and/or cable?
DoctorBill
Old 12-10-2006, 01:37 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Question about Clutches
would check the cable first. sometimes the cable inside the sheath starts to fray and pedal get stiffer. would unhook it and push cable in and out with fingers and see how it feels. when you do this though it may unhook itself under the dash and it takes a bit of work to hook it back up again
Old 12-10-2006, 08:54 AM
91Caprice9c1 91Caprice9c1 is offline
yeah, sounds like a cable to me. check it out - you don't want it snapping in service =)
Old 12-10-2006, 04:28 PM
Crvett69's Avatar
also check where cable bolts to firewall. seen the firewall crack there
Old 12-10-2006, 06:08 PM
DOCTORBILL's Avatar
Geo Metro Lover
Sounds like time to take it to a Shop and let some other poor bugger work on it.
My wife's beloved Tracker....note the Gawd Awful color!
It is not fit for man nor beast outside, I have a code-in-my-node, and am too
damned old to be bending and twisting my sore old bones under the dash of
my wife's Tracker and cutting my hands on frayed cables.
I'll take it to a shop I know and get my wallet pillaged by the Automotive Vikings.
DoctorBill
