Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 12-09-2006, 07:21 PM
heckelman87 heckelman87 is offline
Driving Light and Noise from Steering Column
About four months ago my left turn signal went out, after I replaced it, I noticed that the light blinks when I engage my turn signal, but when I turn my lights on, it stays dark (as opposed to turning on dimmed). I was wondering if you think it is a problem with the bulb, or an electrical problem.
Also,
When turning while my Jeep is still cold the steering column makes a loud squeeling noise. Any thoughts on what might be the problem?
Old 12-11-2006, 08:27 AM
tomvid tomvid is offline
Re: Driving Light and Noise from Steering Column
My steering column makes that noise cold too. I think it is just the plastic on the column rubbing, but I havent figured it out for sure.
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
