Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 12-09-2006, 09:50 AM
gbeck43 gbeck43 is offline
Angry 96 Olds Delta 88 Dying!!!
I have a 96 Olds Delta 88 that dies when going down the road! Two years ago I took the car to a GM dealership to have fix. They had it for 2 months becuase they could not get the car to die, finally it did. Replaced fuel system and PAYD 500.00 dollars. Drove it of the lot the same day and car died again. Too it back to them, they said they found a wire short underneath the drivers side seat. They fixed the problem. Two years later its started again can be driving down the road and the car dies. Let it set for a little while and it will start again. Go down the road again and it will die!! PLease help!! I dont know what to do!!!! Gregory Thank You!
Old 12-09-2006, 01:17 PM
maxwedge maxwedge is offline
A990 racer
Re: 96 Olds Delta 88 Dying!!!
Welcome to AF, without some basic checking here, where do we start , got fuel pressure, got spark, these things are step one towards finding the problem.
Old 12-10-2006, 02:06 PM
sideshowbob sideshowbob is offline
Sounds like the stereotypical crank position sensor problem. Have the codes read for free at your local autozone, though that problem doesn't always set one. When's the last time you changed your fuel/air filters? What other maintenance have you recently done? Look under the driver's seat and check their repair from two years ago while you're at it.
IronLizard's Workshop
Old 12-24-2006, 04:23 PM
niemo810 niemo810 is offline
Send a message via AIM to niemo810
I had the same problem, and it was very annoying.
I did some troubleshooting and found that when I unplug my EGR valve, the car doesn't die while I'm driving down the road. This of course sets off the check engine light, but hey at least my car doesnt die anymore This of course isn't the optimal fix, but try it. If you dont have enough money for a new one, (theyre expensive) just leave it off until inspection time
Old 12-25-2006, 12:20 PM
A990 racer
Exclamation Re: 96 Olds Delta 88 Dying!!!
You need to rethink this advice, the egr's function is to reduce nox by cooling the combustuion chamber, disabling it's function can also cause "pinging" which will cause the pcm to retard the timing and hence performance is affected, not good advice here.
Old 12-26-2006, 11:43 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Definately check for codes, but off hand this sound like either a faulty crank position sensor, faulty ICM, or overheating coil.
And as for the EGR, the passageways could just be clogged with carbon build-up.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 12-28-2006, 12:22 PM
so that's why it's pinging! sometimes i should just shut my mouth about how i've "fixed" my own problems. sorry for the bad advice!!
