Old 12-09-2006, 09:33 AM
dasupa dasupa is offline
96 lumina throwing code 306
just bought a 96 monday, knew the check engine light was on figured i could fix it quick but i was wrong. i changed the spark plugs, wires and coil pack but neither of them cleared the code. any other ideas of what it may be??? or is there something else i should change or check???
Old 12-09-2006, 01:23 PM
maxwedge maxwedge is offline
A990 racer
Re: 96 lumina throwing code 306
Welcome to AF, can you feel a miss in the engine at idle or under load? When you say cleared the code, you have to clear the code unless you drive it thru several cycles and the pcm sees the problem is gone.
Old 12-09-2006, 02:34 PM
well i can't hear or feel it miss but it's like a vacuum line is disconnected or something would that cause it?
Old 12-09-2006, 02:47 PM
A990 racer
If it was a large enough vacuum leak to set a misfire code you would know it for sure. As I said did you clear the code and it came right back or is the lite still on after the work was done?
Old 12-09-2006, 07:23 PM
no i cleared the code and it came right back. the check engine light stays on while driving and then sometimes flashes and then goes back to solid
Old 12-09-2006, 07:33 PM
A990 racer
Then the problem as far as the pcm is concerned still exists, check the injector on #6 possibly bad or bad connector, not easy to access here though, additional full scans may be required to check misfire counts and do an injector balance test, this assumes all the usual tune up issues are done properly.
Old 12-10-2006, 06:42 AM
wafrederick wafrederick is offline
Banned
The 3100 has problems with fuel injectors and that is the next step.Try changing the #6 injector.
Old 12-10-2006, 09:51 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
im ALWAYS going to argue this guy's! why replace plugs and wires and injectors on a vehicle with low compression in the misfiring cylinder? Man, id almost get a compression tester and check compression on ALL cylinders, and then may try a snap compression test to rule out a weak valve spring. "Lets eliminate the basics here"
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-10-2006, 10:30 AM
A990 racer
Thumbs up Re: 96 lumina throwing code 306
Hey, sounds like my standard "basic diagnostics here" all too common statement, very true.
