Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 12-08-2006, 11:36 PM
raiderphil raiderphil is offline
2001 Corrola Heating Problems
I have a 2001 Corolla that blows cold air when at idle. When I start to excelerate then warm air starts to blow. What could be causing this?
Old 12-09-2006, 06:10 AM
KimMG KimMG is offline
AF - Advisor
Re: 2001 Corrola Heating Problems
Worn out water pump
Low coolant level
Old 12-09-2006, 08:31 AM
KigMG,
The car only has 60,000 miles on it. Would it be normal for a water pump to worn out on it with this low miles. I have owned 6 corolla's and all of them had 150,000 plus on them I never had a water pump be worn out. I know it can happen but this would be an oddity. I will check the coolant level to make sure this is the issue.
Old 12-11-2006, 02:35 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Two big ifs. If your ventilation system is vacuum actuated and if the heat temperature varies very close to the time you move the accelerator, you could have a vacuum issue such as a leak or a malfunctioning vacuum regulator.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
