Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-08-2006, 03:06 PM
Prime First's Avatar
Prime First Prime First is offline
Send a message via AIM to Prime First
Won't start :(
Hey, guys.
I've got a '99 Eclipse 420A. It takes me a few times to actually get the car started each day. On first try, the indicator lights will go crazy and there will be a fast-paced ticking coming from the dash. I'll hear the engine murmur a little bit. After a couple tries, I can usually get it to turn over. But today, I've had no luck.
It's been rather cold lately and I did leave the hatch open for a long time about a month and a half ago. So that probably didn't help. I would go get my battery tested, once I get my car started.
Any other suggestions?
Also, where is the O2 sensors located?
Thanks for your help.
Prime First
1999 Mitsubishi Eclipse
10th Anniversary Edition
Old 12-08-2006, 03:28 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Won't start :(
Originally Posted by Prime First
Hey, guys.
It sounds like a battery, or maybe your starter from the way you describe the clicking.
O2 sensors, one is after the catalytic converter, and one is before. I'm not a 420a man so I don't know if the first 02 sensor is on the bottom of the header or the beggining of the mid pipe.
1991 GSX 2.3 Stroker
Old 12-08-2006, 03:31 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Re: Won't start :(
A clicking sound from things like relays and the sorts can be either a shot battery or poorly grounded. Clean your terminal connections from all corrosion and such forth.
2004 Mazda 6i
1997 Tahoe
Old 12-08-2006, 06:18 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Won't start :(
for cleaning and tightening battery/alternator connections. Sounds like either a bad connection or a shitty starter.
95 Talon TSI AWD
97 Eclipse GST
Old 09-03-2007, 04:43 PM
bjd2417 bjd2417 is offline
Re: Won't start :(
Does anyone know where the starter is located in a 2000 Mitsubishi Eclipse?
Old 09-03-2007, 08:56 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Won't start :(
umm... Nope
Maybe you should post this in the 2000+ sections.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
