transmisson fluid
well i want to replace the transmisson fuild on my 2001, 1500, 2 wd suburban, of course it automatic. i know the transmisson fuild is suposed to be life time but i think thats all b.s. well my question is how do u change the fuild? i hread it's like a oil change but i wouldn't know what to unscrew and ect.
Re: transmisson fluid
Your transmission won't have a drain plug on it, so you will have to remove the pan and let it pour out. Take the pan off anyway so you can replace your filter, and while you have the pan off, you can add a drain plug to it.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
yeah i want to change the filter too. but anyways how do i add a drain plug?
Your vehicle came with an owners manual. In it is the maintenance schedule for your vehicle. Information like this is in there Quote:
Raise and support the vehicle. Remove the catalytic converter. (you can get around this by loosening the trans mount and jacking the back of the trans up) Place a drain pan under the transmission oil pan. Remove the oil pan drain plug, if equipped. If necessary, remove the bolts and position aside the range selector cable bracket for clearance while lowering the pan. It is not necessary to remove the cable from the lever or bracket. Remove the oil pan bolts from the front and sides of the pan only. Loosen the rear oil pan bolts approximately 4 turns. Lightly tap the oil pan with a rubber mallet in order to loosen the pan to allow the fluid to drain. Remove the remaining oil pan bolts. Remove the oil pan and the gasket. Grasp firmly while pulling down with a twisting motion in order to remove the filter. Remove the filter seal. The filter seal may be stuck in the pump. If necessary, carefully use pliers or another suitable tool to remove the seal. Discard the seal. Inspect the fluid color. Clean the transmission case and the oil pan gasket surfaces with solvent, and air dry. You must remove all traces of the old gasket material. Installation Procedure Coat the new filter seal with automatic transmission fluid. Install the new filter seal into the transmission case. Tap the seal into place using a suitable size socket. Install the new filter into the case. Install the oil pan and a new gasket. Tighten the oil pan to transmission case bolts alternately and evenly to 11 N·m (97 lb in). If previously removed, install the range selector cable bracket and bolts. Tighten the bolts to 25 N·m (18 lb ft). Install the catalytic converter. Lower the vehicle. Fill the transmission to the proper level with DEXRON® III transmission fluid. Check the COLD fluid level reading for initial fill only. Inspect the oil pan gasket for leaks.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
I'm with Merlin. The Owner's Manual clearly states either a 15,000 or 50,000 miles transmission oil change depending upon your type of driving. I'm very curious about where you heard/read/saw that transmission oil is a "lifetime" service interval.
Be safe, and split the difference at 30,000. If you want it to be easier next time, install a drain plug this time.
Where i hread about it being life time was from my auto shop teacher but he was always a dumbass plus the manuel in my car is pretty f***ed up it's messing pages and stuff!!!!!
If your Owner's Manual is damaged, log in and download a new one:
https://www.mygmlink.com/main/US/en/gm/home |
hahaha i know but thanks for all your help guys!!!!!!!!
I use the end of a 55 gal drum for a catch pan. Your transmission may have a drain plug and a reusable pan gasket. If it has the thick hard rubber molded gasket reuse it. Good for 3-4 or more changes. And a lot better than that cheap gasket that comes with a after market filter kit.
