Go Back   Automotive Forums Car Chat > Ford > Contour
Old 12-08-2006, 12:06 AM
spoolinmonkey spoolinmonkey is offline
Thumbs down 99 contour svt running VERY ruff new cold air problem?
My probably about two weeks ago when i would start my car the idle would rise and drop about 250rpm but now its much worse. It sounds like when a muscle car has those mis idle cams in it and it goes....vrrr.....vrrr........vrrrrr when i start it and the engines is cold,
then it will rev it too anywere to 2-3k rpm then drop again to an idle or more and sputter and somtimes stall. i recently put a new performance filter and a jimmy-rigged intake...and were i live up here in canada it has been getting very cold somtimes -25 -30 degrees, i talked to a few guys who said all the cold air might be throwing my engine and computer off...what do you guys think... im putting the stock intake back on soon hopefully that will help...thanx guys
Old 12-08-2006, 09:14 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 99 contour svt running VERY ruff new cold air problem?
Sounds like an IAC issue. This is covered in the FAQs.
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=7
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
